Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
After reading about Purple's findings on his brakes (BIG TIME YIKES!!!!) I realized I better take a full day or two and go through EVERYTHING on my car just to be double sure she is safe and as reliable as she can be (all things considered..... LOL)
I know the PCA has a Porsche related chacklist for racing A/X but has someone compiled a 914 related checklist covering known issues with our cars? Things like E-brake adjusting which is something I know I need to fine tune on my car. Also fine tuning the alignment so I can attack the twisties more safely. Noted early tire wear to indicate this issue.... Check motor mount bolts, belts, cleaning fuses, battery servicing, clutch adjust, purchasing backup throttle and clutch cables, handle nagging oil leaks, tune-up, are some other things that come to mind. Anyone have a comprehensive spring time list? (IMG:style_emoticons/default/driving.gif) |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
my checklist has always been:
engine runs - check drive jim * maybe i should add a few more : ) |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
CV bolts, throttle and clutch cable, speedo cable, clutch adjustment....
for me, i have to change steering rack boots and tie rod end boots, and replace the o-ring in the speedo angle drive...... |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
my checklist has always been: engine runs - check drive jim * maybe i should add a few more : ) Joint butts OUT of car (IMG:style_emoticons/default/dry.gif) I got really tired of those things flyuing up in my face when you took me for a ride Jim (IMG:style_emoticons/default/smoke.gif) |
Dr. Roger |
that's funny. when i took possession of my 914 i found a roach in the ash tray.
friggin' stoners.... LOL (IMG:style_emoticons/default/happy11.gif) |
Lo-Fi Version | Time is now: 16th July 2025 - 10:17 PM |
