Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I need some diagnostic help.
Car started missing at low rpm's only. I thought that it could be a clogged idle jet or poor connection on one of my plug wires (it fits kinda loose). Pulled all the idle jets and cleaned them up. Crimped the plug connection so it fits better. No luck. Now it's even worse. Not a miss anymore but what feels like a dead cylinder at low rpm's. It seems to clear up at higher rpm's but the motor just doesn't seem to pull as strong. Ideas please... (IMG:style_emoticons/default/smile.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Compression test (IMG:style_emoticons/default/sad.gif)
Allan |
Wouldn't it be better to start with pulling plug wires to find out which cylinder isn't firing first? I'm going to try that tomorrow, then I'll check all the plugs and see if one of the looks like it's fouling. |
Dr Evil |
Well, I would have figured you tried that first (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/rolleyes.gif)
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
AFTER you find the one not working, test the wire on the dead cylinder with a fluke....they do die ya know. Could also be the BERU connector end....ya know....the rubber cap thingy that fits over the plug.
Could be as simple as a fouled plug.... |
Allan |
Not yet.
Just took the daughter out for ice cream in it and now it's too dark. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
Heh....I can locate the missing cylinder, pull the offending plug, gap and install the new one in 3-4 minutes.....did so in the staging lanes of the 2006 Parade AX while carrying on a conversation with Steve Wiener on my choice of heat ranges.
As you can tell, this is not an uncommon occurrence. (IMG:style_emoticons/default/biggrin.gif) |
Joe Bob |
So????
Allan |
So???? Looks like it's gonna be tomorrow at lunch. I ran off and left my high-voltage gloves at the office (i know I'm a wuss)... (IMG:style_emoticons/default/biggrin.gif) |
Joe Bob |
Prolly next to yer "Man Card".... (IMG:style_emoticons/default/piratenanner.gif)
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
"high-voltage gloves " (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif)
i don't care you ya are thats funny!!!! (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) |
Smitty911 |
Member ![]() ![]() Group: Members Posts: 294 Joined: 19-March 08 From: La Mirada, Ca Member No.: 8,830 Region Association: Southern California ![]() |
What's the problem you have one more cylinder running than I have. LOL
No help sorry. Smitty |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
On my 4 cylinder engine, I found the non-firing cylinder by running the engine a bit then touching the 4 exhaust pipes to find the cold or not-so-hot one. Takes out all the guess work of finding a dead cylinder.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
Even though you've cleaned all of the idle jets you still can't rule it out. I've had times when one would repeatedly clog and another time where one had a very thin flake of something that would turn one way and open the flow and then turn another and allow the car to idle again. After you think that they're all clean and they're all installed you can loosen each jet holder, one by one, about 1/2-3/4 turn. If it stays the same or runs worse, that jet is clean. If it cleans up and idles well, that jet is clogged. It's a really quick way to check your work.
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,096 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) BTDT myself. Little flaky crap that kept reappearing and clogging a jet after it had just been cleaned.
Allan |
"high-voltage gloves " (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) i don't care you ya are thats funny!!!! (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) You thought I was kidding? (IMG:style_emoticons/default/huh.gif) Attached image(s) ![]() |
Allan |
Anyway, I have narrowed it down to the #2 cylinder.
Pulled that plug wire and the motor didn't change a bit. All the rest of them were firing well. Before I did that I changed all the plug wires with new Magnecore's I'm gonna swap the plug now and see if that helps. |
SGB |
just visiting ![]() ![]() ![]() ![]() Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States ![]() |
Magnacores drove me crazy. They would not secure well to the plug tip. I went back to old style push-on over the threads bosch wiires.
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,730 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
If it smooths out at upper RPM's, it's probably your idle circut. Take that idle jet back out with the car running and tap your finger over the hole. I know it sounds kinda dorky, but your finger will create a little pressure/vac while you tap it. Doesn't always work. But often I have done that, put the jet back in and the car idles perfect again.
(IMG:style_emoticons/default/confused24.gif) |
Allan |
Well, that was a big waste of time. (IMG:style_emoticons/default/mad.gif)
Re-cleaned the idle jet for that cylinder and I even tried Dan's suggestion and it didn't help. How can I tell if it's the idle circuit and not just the jet? |
Lo-Fi Version | Time is now: 6th July 2025 - 10:33 AM |
