Of the Six's: Whose windshield washers work?, How much is still working? |
olav |
Jan 7 2003, 05:32 PM
Senior Member Group: Retired Members Posts: 1,107 Joined: 28-December 02 From: Los Gatos, CA. USA Member No.: 34 Region Association: None |
Since there are a few six owners here I jut thought I would ask.
I have had my six for about four years now and just got around to getting my electric windshield washers to work. I had to get new washer jets, take out the electric pump and "recondition" it. I also has to unjam the little valve in the windshield washer water bottle (say that six times). Then I got some new modern blue windshield washing fluid to replace the factory original fluid. Now everything works great, they spray up a storm and I have even used them for legitimate reasons once or twice while driving. Now I think everything works on my car the way it should even the rear trunk light works I just found out. One other thing: my original turn signal relay gave up the ghost and I bought a new one. Now the turn signals in the tach blink individually according to the direction you are signaling to turn. The old style signal relay just made both light blink no matter what direction you are turning. I like it better now. - Olav |
Gint |
Jan 7 2003, 05:58 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Never really saw the question. (IMG:style_emoticons/default/rolleyes.gif)
Sounds good. When I hit the washer switch all I get is a blown fuse. |
Jeroen |
Jan 7 2003, 06:49 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Olav wrote: "...even the rear trunk light works I just found out..."
Did you crawl into the trunk to check if the light really is off with the lid closed? (IMG:style_emoticons/default/biggrin.gif) Cheers, Jeroen |
BS Chairman |
Jan 7 2003, 07:01 PM
Member Group: Members Posts: 98 Joined: 27-December 02 From: Southeast Michigan Member No.: 28 |
Never tried mine! I've had the car going on six years now, never thought about them. The wipers do work low and high but no wait a minute swipe. Funny how you never miss things.
drew365 |
Jan 7 2003, 08:14 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
Olav; 1. We don't need no stinking washers! (IMG:style_emoticons/default/tongue.gif)
2. My left turn blinkers just started making both arrows blink on the dash. So you say it's the relay? I checked the bulbs but I didn't go any further. I was thinking, We don't need no stinking turn signals. Obviously my cars not headed for any concours. |
olav |
Jan 7 2003, 08:26 PM
QUOTE(drew365 @ Jan 7 2003, 06:14 PM) 2. My left turn blinkers just started making both arrows blink on the dash. So you say it's the relay? I checked the bulbs but I didn't go any further. I was thinking, We don't need no stinking turn signals. Obviously my cars not headed for any concours. Hmmm, that sounds more like a ground problem. Check the wires on the back of the tach. The brown wire(on mine anyway) is ground. |
Brad Roberts |
Jan 7 2003, 11:35 PM
I said it six times.. but nothing happened. The washer motor came on when I tested it in Muellers 9146..nothing hit the windshield... but the bottle is empty. I'll put some fluid in it *after* I get it running.
B |
Lo-Fi Version | Time is now: 12th June 2024 - 09:11 AM |
