zonedoubt |
Canadian Member ![]() ![]() ![]() Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada ![]() |
What are these holes for? Are they supposed to plugged?
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
I haven't done much with type4's in a long while but. I believe the big one is for timing. There should be timing marks on the flywheel. Others can chime in on the small one. I believe there's a plastic cover that goes over the big hole. Again, not too sure on the other.
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
those are there for the mice to come out and get water and food when the car is parked, they do get hungry with you stepping on the long pedal all the time (IMG:style_emoticons/default/happy11.gif)
i think that there just there for venting of the clutch, there is another hole kinda shaped like a notch on the bottom that can be used for setting valve lash. check with the pelican parts they have a tech article on that |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,445 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
The big one up at the top is for a Vanagon with an automatic transmission. It is used to install and tighten the torque converter bolts.
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
The small one is to strip the flesh off of your finger if you stick it in there to move the engine around on the floor of your garage.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,204 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Isn't the little one for some kind of sensor that was used for diagnostics on some of the Buses?
Neither one is particularly useful on a 914. --DD |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Isn't the little one for some kind of sensor that was used for diagnostics on some of the Buses? (IMG:style_emoticons/default/agree.gif) on my '81 vanagon, there is a sensor in the top hole probably for magnetic signal to know RPM. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
(IMG:style_emoticons/default/agree.gif) the little one is bus 'diagnostics'.
Eric_Shea |
(IMG:style_emoticons/default/av-943.gif) Really glad I could help out in this thread. (IMG:style_emoticons/default/lol3.gif)
Lo-Fi Version | Time is now: 15th July 2025 - 12:24 AM |
