Replacing center tunnel feul lines |
dbgriffith75 |
May 28 2008, 11:26 AM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
I've already removed the old lines so as to get them out of the way when I do the paint, and what I've done to aid in feeding the new lines is I fed light gauge wire through the old lines before removing them, then just tied bolts to each end of the wire to prevent them from falling out. It may not be the best way, but it's at least a guide.
Anyway, I'd like to know what's reccomended to do replace them with. As you can imagine the old plastic lines are frail and brittle, and I've already broken them more than once. I'd like to replace them with steel lines. But would aluminum/copper/brass be better? |
plymouth37 |
May 28 2008, 11:36 AM
Senior Member Group: Members Posts: 1,825 Joined: 24-May 05 From: Snoqualmie, WA Member No.: 4,138 Region Association: Pacific Northwest |
I would go with stainless, Tangerine Racing (CFR) makes a nice kit. Here is the LINK
VaccaRabite |
May 28 2008, 11:37 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
CFR stainless steel fuel lines are the way to go, if you want pre-bent.
Make your own from stainless brake line if you want to save money and DIY. Zach |
ericread |
May 28 2008, 11:41 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Take a look at Tangerine Racing. The basic set is $85.00. Takes an hour or so to install and they are really high quality. As a representative CSOB, I say it's the only way to go.
Eric BTW: Tangerine Racing = CFR; Same dude. |
dbgriffith75 |
May 28 2008, 01:52 PM
Right on! Consider it DONE!
Lo-Fi Version | Time is now: 7th June 2024 - 08:51 PM |
