lower tin, where does it go? |
mattp |
May 28 2008, 07:41 PM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
putting together an engine and cannot figure out where the lower tin goes or what it attaches to. HELP!
r_towle |
May 28 2008, 08:25 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
four pieces
two go between the pushrods tubes and the head. two go under the push rod tubes. Rich |
type47 |
May 28 2008, 08:42 PM
number 5 is under the cylinders, over the pushrod tubes (as stated above) and 11 and 12 are mounted to the case and the heat exchangers
Attached File(s) 914_engine_tin_AA.doc ( 92k ) Number of downloads: 138 |
mattp |
May 28 2008, 08:58 PM
its 11 and 12, what do they bolt onto? O cant find any place to bolt them to the case! I assume they bolt to case then to heat exchangers after?
thanks |
type47 |
May 29 2008, 08:58 AM
its 11 and 12, what do they bolt onto? there are 3 - 6mm bolts (hex head or cheese head) that attach 11 and 12. there is one bolt that goes into a little ..... boss.... protrusion... thing that sticks out of the case and is tapped for the 6mm. two other bolts fit into tapped captured nuts or threads on the heat exchanger outer covering. there is a difference in one of the 11 or 12 parts between side shifter and tail shifter. for tail shifter, piece covers shift rod, for side shift rod is under the piece (not covered) |
mattp |
May 29 2008, 10:25 AM
found it! Thanks a ton. Matt
Lo-Fi Version | Time is now: 8th June 2024 - 11:51 AM |
