air pump, to keep or ? |
gity |
May 29 2008, 12:07 PM
Newbie Group: Members Posts: 1 Joined: 29-May 08 From: oregon Member No.: 9,114 Region Association: None |
I have a 76 914 with the air pump. I do not have to meet any smog req. where I live. Should I remove the air pump and tubing? Any good or bad results? Best way to plug holes? I also have a hesitation at about 4k with stock FI.
blitZ |
May 29 2008, 12:17 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I removed mine as there is no smog regulation for older cars here. It's less clutter in the engine compartment. I had plugged mine with bolts, but had Len weld them shut when the heads were rebuilt.
Cupomeat |
May 29 2008, 12:19 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
Is it a D-jet (2.0l) or an L-Jet (1.8l)?
The troubleshooting methods are very different depending. As I think there were almost no 1.8l 1976 914s, I suppose it is a 2.0l. If so, check the temperature sensor in the head, many are faulty and can cause a hesitation. As for the Air pump, I'd remove it and plug the holes. Then get an A/F meter and adject the mixture as per D-Jet specs. Shouldn't be much different as it is only dumping air to the exhaust side. |
Jeffs9146 |
May 29 2008, 12:31 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
If you ever plan on selling it and you don't want to eliminate California buyers then you should leave it on or at least save it! A 76 needs smog in CA.
So.Cal.914 |
May 29 2008, 12:40 PM
If you ever plan on selling it and you don't want to eliminate California buyers then you should leave it on or at least save it! A 76 needs smog in CA. (IMG:style_emoticons/default/agree.gif) |
Rand |
May 29 2008, 04:09 PM
Will the CA smog requirement continue to be according to the manufacture date of 1976, or at 32 years of age (or whatever)?
I'm glad we are exempt up here, but I think our system is based on the age of the car. If '76 had smog requirements this year, it would become exempt next year. |
hcdmueller |
May 29 2008, 05:44 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
If you don't want to completely remove the system just take out the pump and leave the metal tubing in place.
I did that to mine and the engine ran smoother. It also got rid of the annoying popping in the exhaust on decel. I thought about plugging the holes into the head but the thread pitch is odd and I had trouble finding the right size bolts. My car came from California. I got the feeling nobody there was willing to deal with the emissions even though my car was completely stock an running very well. |
Lo-Fi Version | Time is now: 7th June 2024 - 12:21 PM |
