Is it all here?, smog stuff / before classifieds |
stateofidleness |
May 31 2008, 01:09 PM
Senior Member Group: Members Posts: 810 Joined: 1-September 07 From: Canyon Lake, Texas! Member No.: 8,065 Region Association: None |
Hey guys,
I just wanted to see if I have everything that would be necessary to install the smog stuff before I post it in the classifieds. I want whoever needs it to have everything they'll need once it arrives. From the picture, does it look like anything is missing? any idea what I should be asking for it? need to make an autoatlanta purchase (IMG:style_emoticons/default/smile.gif) |
sean_v8_914 |
May 31 2008, 04:15 PM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
missing:
pulley that mounts to fan long skinny pipe that goes from EGR to rear exhaust pipe that goes from rubber belows intake hose to EGR thing and y branch to idle over run aux air thing CAT |
Krieger |
May 31 2008, 08:47 PM
Advanced Member Group: Members Posts: 4,729 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I don't see the actual "air injectors" that screw into the head. Should have four of them that the big octopuss tubing thing you do have pictured atatches to.
stateofidleness |
May 31 2008, 11:27 PM
i know i have the pulley still and im not sure which pipe you're talking about with the "rubber bellows".. ill have to look again. I know i dont have the skinny pipe to the exhaust, but i DO have the 4 air injectors. it was my understanding that those should be left in and capped? or is there a bolt that will fit in there?
any idea what it's worth (the stuff i DO have) |
ConeDodger |
Jun 1 2008, 11:41 AM
Apex killer! Group: Members Posts: 23,616 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Something I didn't know about but is technically part of the smog system is under your carpet on the passenger footwell. It is your mileage counter. It triggers your check engine light when you reach certain mileage marks. It isn't there either. I discovered yesterday when I installed the Appearance and Performance sub box and had to remove it. McMark told me what it was.
Remember, your market is small. You only sell that stuff to originality freaks, guys in States that require inspections. In California that is only the '76 and I think many of these bpcome parts cars or race cars if they have good bodies. So your value is "not much"... |
Lo-Fi Version | Time is now: 12th June 2024 - 04:42 AM |
