sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
I hope this helps ya'll.
Attached thumbnail(s) ![]() |
sean_v8_914 |
the angles are like gear ratios
sean_v8_914 |
fth
sean_v8_914 |
sfdh
sean_v8_914 |
gfshs
Attached image(s) ![]() |
sean_v8_914 |
the drop arm to the butterflies is wrong here. it gives slow initial response relative to pedal travel making 70% to 100% feel stiffer.
sean_v8_914 |
cable is straight relative to the pull travel.
purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
correct me if i'm wrong, but isnt it best to have the drop arms as close to vertical as possible, merely for the fact that it's easier to 'see' if you're off or not?
sean_v8_914 |
if your talking about the arms from the hex to the carb butterfly cam...yes, as close to vert as possible, however, teh carbs are off-set left to right front to rear so it is a compromise to get close. one carb butterfly pivot has a long space to help this.
angle X in dwg # 1 should be as vertical as you can get it but MUST be the same left to right |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i don't know how you guys can stand to deal with your carbs with the linkage on the rear side.
common angularity is the goal. throughout the range of motion. |
Kargeek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 ![]() |
[i don't know how you guys can stand to deal with your carbs with the linkage on the rear side.
common angularity is the goal. throughout the range of motion.] It's the same front or back- it's how you align the linkage and set up the cable bracket. DH Attached thumbnail(s) ![]() |
rhodyguy |
i know the adj procedure is the same whether rear or front mounted linkage. it's the physical aspect of dealing with the droplinks and reaching around with the rear trunk hood in the way in what i consider a rather confined space.
sean_v8_914 |
good point. show us a pic of your setup.
Kargeek, I like your throttle cable bracket. it is simple and clean. can you post a close up of teh cable routing. this bracket seems to be where most guys cheese out |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
rhodyguy |
got this via the search feature. triad+linkage produces 4 pages of results. some of it's pretty funny. when my camera comes home i'll take a better photo.
sean_v8_914 |
that flexy cable holder is the culprit
I prefer lighter dual return springs |
rhodyguy |
are you refering to mine?
sean_v8_914 |
one spring on each carb.
ya. not in love with your setup. the arms stood up like that give a non linear opening progression making top end throttle modulation more difficult. it is not something one could appreciate while street driving. in a performance environment it makes a difference. |
EyeTrip |
Member ![]() ![]() Group: Members Posts: 104 Joined: 29-May 07 From: Camas, Wa Member No.: 7,767 Region Association: None ![]() |
One spring on each carb.
Mine pulls from the top side, seems to be easyer to adjust. Done it both ways. |
Lo-Fi Version | Time is now: 17th June 2024 - 07:14 AM |
