bent engine mount use, fix or replace, need advice |
tmh75 |
Jun 8 2008, 12:50 PM
Member Group: Members Posts: 74 Joined: 25-January 05 From: bozeman, mt Member No.: 3,506 |
I'm finally putting the engine and car back together after a 3 year rebuild (to busy to dedicate the time to it till now). Modified the engine mount last night, to compensate for new Raby full flow oil system, and noticed that it is bent. I bought the car for $600 and probably have $5000 in it by now and have maybe driven it 50 miles. Once it runs it may see 3000 miles/year So here are my questions:
1. Do you think it is bent enough to be a concern? I'm most concerned with how it may throw everything else off, i.e. trans ect.. To use it that way it is i was going to enlarge the upper left hole to match engine hole. If I go this route should I shim one side? 2. Should I heat it up and bend it back? 3. Buy new unbent mount? Thanks it advance, here are pics. I like to think that I'm overthinking the whole thing, but they maybe because I just want to drive my @#$ car. |
tmh75 |
Jun 8 2008, 01:02 PM
IronHillRestorations |
Jun 8 2008, 01:15 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Ideally you'd just get a new mount and wash your hands of the bent one. It depends on how much of a hurry you are in. If you are pressed for time just elongate the holes to fit.
rhodyguy |
Jun 8 2008, 10:24 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the popularity of side shift conversions should make for plenty of the early style ones being available. post a wtb. should be pretty cheap.
k |
tmh75 |
Jun 8 2008, 10:26 PM
Thanks,
WTB now listed |
Cap'n Krusty |
Jun 9 2008, 12:02 AM
I'm sure I have a couple. PM me. The Cap'n
Lo-Fi Version | Time is now: 9th June 2024 - 05:04 PM |
