Seat Height Spring, How do you remove it? |
chris914 |
Jun 12 2008, 04:36 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
I want to remove the spring and adjuster lever so I can paint the base.
What’s the best way to remove the spring and then put it back together later? I’m pretty sure I can get it apart. What’s the procedure or tricks? |
SLITS |
Jun 12 2008, 07:27 PM
Use a screwdriver to pop the spring off the roll pin .... drive the roll pin out
Or Actually, paint the whole damn thing unless you're goin' for CW points. Or Tape the spring & such off and paint the rest |
SGB |
Jun 12 2008, 08:58 PM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
Ron's right. Clean it and paint it intact. Put it all together and don't look back. (IMG:style_emoticons/default/smile.gif)
chris914 |
Jun 13 2008, 02:22 AM
Most paints don’t like galvanized metal.
It ended up coming apart without too much trouble. I pressed the pin most of the way out. Then lifted the spring over the rolled pin. After that I pressed the pin all the way out. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:42 AM |
