8mm Plug Wires, Do they fit? |
wertygrog |
Jun 23 2008, 12:02 AM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
Hi,
I've done a search but I couldn't find this nugget of info: I'm wondering whether the 8mm magnecor plug wires fit in the black wire clips on the type 4 tin, or whether they'll only take 7mm wire. I ask because the 8mm stuff seems much easier to find (pelican says "ships in 5 days" for their 7mm electrosports (IMG:style_emoticons/default/bootyshake.gif) ), but apex performance has the 8mm wires for about 30 bucks. But I don't want to go through the hassle of figuring out how to mount the wires if the stock clips won't work.... thanks for your help! (IMG:style_emoticons/default/smilie_pokal.gif) |
SLITS |
Jun 23 2008, 12:13 AM
1 silly millimeter .... plastic should spread that much and the rubber can compress.
Most cars I've seen don't have them anyway. Heat makes em brittle and they break. |
tango-52 |
Jun 23 2008, 12:40 AM
Member Group: Members Posts: 149 Joined: 18-October 07 From: San Diego County Member No.: 8,243 Region Association: Southern California |
I have the 8mm on mine. You can roll them into the clips, or use a little WD40. But the old clips are brittle and will break even with standard wires.
wertygrog |
Jun 23 2008, 11:01 AM
Thanks guys! Now what do you replace the old clips with? FLAPS item?
tango-52 |
Jun 23 2008, 01:14 PM
Lo-Fi Version | Time is now: 10th June 2024 - 01:37 AM |
