> Steering Wheel Play, Too Much Movement
dale 914
post Jun 28 2008, 10:28 AM
All,
I am sure you have seen this before. I just bought my first 914 a couple of weeks ago, so I am still in the dark!
Anyway, the steering wheel had lots of movement in it. After researching it, I bought one of the metal bushings and installed it, pretty easy. Well, that eliminated about 70% of the movement, how do I eliminate the last 30%? It seems that that the bushing was not "thick" enough. I believe all of the movement still resides at the steering wheel itself rather than further down the column.
Thoughts?
Thanks
Dale (IMG:style_emoticons/default/headbang.gif)
Replies(1 - 2)
ericread
post Jun 28 2008, 12:43 PM
The Viper Blue 914
I had the same problem. You probably need to remove the steering column and replace the entire upper bearing. I found that the sleeve didn't provide enough play reduction for me, and upon dissassembly, founnd the old bearing to be shot.
When I replaced the bearing, I still noticed some play between the outside of the bearing and the steering wheel race. I tightened that up by using a few mils of aluminum foil as a shim between the race and the outside of the bearing. That snigged it up nicely.
Good luck, and enjoy your teener. (IMG:style_emoticons/default/driving.gif)
Eric Read
dale 914
post Jun 28 2008, 01:11 PM
QUOTE(ericread @ Jun 28 2008, 11:43 AM) *
Eric Read
Eric,
thanks, will give it a go.
Dale
- Lo-Fi Version Time is now: 2nd September 2025 - 10:58 PM
