Air flap roller, Living without it |
chris914 |
Jun 28 2008, 09:20 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
Does the bolt that holds on the roller do anything else?
Can I just put a bolt in the hole to plug it after I remove the roller? |
orange914 |
Jun 28 2008, 10:21 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Does the bolt that holds on the roller do anything else? Can I just put a bolt in the hole to plug it after I remove the roller? if your refering to the one in the case, i've heard you'll have a oil leak with out it in. (IMG:style_emoticons/default/huh.gif) |
davep |
Jun 28 2008, 10:22 PM
914 Historian Group: Benefactors Posts: 5,156 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
If you don't have a bolt in the hole, then you will have a major oil leak.
Lo-Fi Version | Time is now: 12th June 2024 - 08:52 PM |
