> Front-End... A-ARM Bushings, What do you do?
jesiv
post Jun 28 2008, 11:17 PM
My front right-rear a-arm bushing has severe play! So I figure, I need to replace the bushings in my a arms. I have heard that stock rubber bushings are not available. But I think I saw some on the bird site. So as I try to decide what to do and find parts the problem festers... So what is the most obvious “upgrade”.. replace “all” the bushing, in the front end, koni shocks, front sway bar, turbo tie-rods. Currently the front end is stock no sway bar. What would you do?
Regards,
James
Replies(1 - 6)
r_towle
post Jun 28 2008, 11:19 PM
Custom Member
Edited , just like the original post,
I give up....
Rich
PeeGreen 914
post Jun 28 2008, 11:52 PM
Well, it really depends on your mechanical experience. I would drop your front end and check everything over. If you find anything to be bad replace it. As for the bushings, if you are just wanting something for a street car I would do the derilin bushings. You need to take some material off to get them to fit right but when you do they fit very nice. Makes you front suspension nice. If you are wanting a track set-up I would do the Elephant Racing set-up. Very nice bushings that are very smooth.
On the other stuff, a front sway will make your car feel great. The Konis will be good as well. Turbo tie rods are nice but I didn't feel as big a difference as I thought I would. Torsion bars can help if you are going to go for more of a track set-up but then you need to do the rear as well.
ejm
post Jun 29 2008, 05:35 AM
I can see the light at the end of the tunnel
QUOTE(Phoenix 914-6GT @ Jun 29 2008, 01:52 AM) *
(IMG:style_emoticons/default/agree.gif) Check out these delrin bushing's. They can be installed without special tools, no pressing or reaming is needed. If the rest of the front end is good a front anti-sway will make a noticeable improvement in handling. If your A arms don't have brackets for the links get some welded on while doing the bushing repair.
rhodyguy
post Jun 29 2008, 12:36 PM
balljoints too. be done with it. if you don't know their age the front wheels bearing. be done with it.
McMark
post Jun 29 2008, 01:57 PM
914 Freak!
FreeMotion Upgrade... (IMG:style_emoticons/default/wink.gif)
Delrin are a suitable replacement.
TeenerTim
post Jun 30 2008, 12:35 PM
QUOTE(rhodyguy @ Jun 29 2008, 02:36 PM) *
Exactly. I replaced the bushings, wheel bearings, the torsion bars, ball joints, turbo tie-rods, and added an anti-sway bar too. It was all part of my five lug conversion. I also got rebuilt calipers from PMB and new hoses and rotors are coming soon. While I was at it I installed the bump-steer kit. I'll be good to go with no worries since everything will be new.
- Lo-Fi Version Time is now: 12th March 2026 - 07:03 AM
