5-lug Spare ? |
5-lug Spare ? |
7275914911 |
Jun 30 2008, 09:47 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
What kind of spare do you use if you have converted to 5-lug. I am wondering if the 911 Space Saver will fit under the targa top in the rear trunk.
Thanks in advance... jkp |
smontanaro |
Jun 30 2008, 09:49 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
My /6 has a full-sized spare. In fact, it's a fifth 5-lug gas burner.
Skip |
jim_hoyland |
Jun 30 2008, 09:50 PM
Get that VIN ? Group: Members Posts: 9,323 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Space saver. You can pick up very good ones for $40-$60. I got mine from Bruce Stone at the G & R Swapmeet in Riverside.
Spoke |
Jun 30 2008, 10:02 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I picked up a nice 14 inch 5-lug Fuch from Camp914.
GeorgeRud |
Jun 30 2008, 10:20 PM
A fullsize spare fits in the rear trunk, in fact there is a threaded connector to even screw the tire into the trunk floor to keep it in place. The targa top fits over it fine as well as it's not ann overly wide tire.
SirAndy |
Jun 30 2008, 10:39 PM
Resident German Group: Admin Posts: 41,682 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What kind of spare do you use if you have converted to 5-lug. I am wondering if the 911 Space Saver will fit under the targa top in the rear trunk. my 7" cookie cutter with a 215/60 tire fits barely under the targa top in the rear trunk. it rubs just a little bit ... i'm going to go with a 6" rim and a 195 tire. shouldn't be any trouble fitting that under the targa top ... (IMG:style_emoticons/default/bye1.gif) Andy |
cobra94563 |
Jun 30 2008, 11:46 PM
Chris Group: Members Posts: 341 Joined: 1-March 05 From: San Francisco Member No.: 3,696 |
I use a space saver... and it fits under the targa top fine.
As others have said, probably a 6in or even a 5 1/2 in might fit, and then you wouldn't have to carry an air pump. |
boxstr |
Jul 1 2008, 12:01 AM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Works everytime.
CCLINSPARETIREINACAN Attached image(s) |
GringoLoco |
Jul 1 2008, 04:40 AM
Member Group: Members Posts: 87 Joined: 24-May 08 From: Tacoma, WA Member No.: 9,100 Region Association: None |
Works everytime. CCLINSPARETIREINACAN (IMG:http://i12.photobucket.com/albums/a210/gringoloko/tire_blowout.jpg) Well, almost every time. (IMG:style_emoticons/default/biggrin.gif) Seriously though, I've had a can of fixaflat bail me out twice now. Both times I had a spare tire in the trunk, but didn't want to change it on the side of the freeway (first time) or in a crappy neighborhood at night (second time). Works quick too. |
jk76.914 |
Jul 1 2008, 05:01 AM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
15 x 4.5 wheel with 135R15 tire. Got the wheel on eBay and the tire from Coker.
7275914911 |
Jul 1 2008, 05:40 AM
nsr-jamie |
Jul 1 2008, 07:30 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
JK.76 914 does it work with your windshield washers? I was going to do something like this too and wonder if I have enough air pressure in there to run them, or will the spare run flat after a couple of uses??
PRS914-6 |
Jul 1 2008, 09:24 AM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
If you have big brakes there is a limited # of wheels that will fit. I used a 964 spare.
cobra94563 |
Jul 1 2008, 01:46 PM
I use a space saver... and it fits under the targa top fine. As others have said, probably a 6in or even a 5 1/2 in might fit, and then you wouldn't have to carry an air pump. So the space saver is flat and has to be inflated? yup. |
Elliot Cannon |
Jul 1 2008, 03:54 PM
I carry the same spare. I use a small pony scuba bottle with a first stage of a scuba regulator to air it up. The small electric pumps work good, just takes a little more time.
Rand |
Jul 1 2008, 04:45 PM
Works everytime. CCLINSPARETIREINACAN This stuff is great, but the last flat I got, something flipped up and punctured the sidewall. (IMG:style_emoticons/default/sad.gif) I'm glad I was carrying a spare that time. Sucked having to replace a nearly new tire. |
jk76.914 |
Jul 1 2008, 08:03 PM
Lo-Fi Version | Time is now: 12th June 2024 - 04:58 PM |
