> 911 SC Oil Gauge in a Getty Dash question....
Joe Bob
post Jul 5 2008, 06:09 PM
Getty dash in my 74....has a 911 SC oil pressure gauge. I need a sender for the idiot light and pressure......I've done this in the past but for the life of me, I can't find any reference to the right VDO combo sensor on the web.
Anyone got any old reference books or a memory that isn't like mine? Everything online references STOCK applications....
Glenn at Pelican came up dry...so I'm not a complete idiot.
Replies(1 - 19)
markb
post Jul 5 2008, 06:36 PM
914less :(
If you figure it out, lemme know. I need the same thing for my car.
ClayPerrine
QUOTE(! @ Jul 5 2008, 07:09 PM) *
Getty dash in my 74....has what looks like a 911 SC oil pressure gauge. I need a sender for the idiot light and pressure......I've done this in the past but for the life of me, I can't find any reference to the right VDO combo sensor on the web.
Get me the part number off the gauge. I can get it cross referenced to the correct sender.
post Jul 5 2008, 06:40 PM
Resident German
QUOTE(ClayPerrine @ Jul 5 2008, 04:36 PM) *
part number of the gauge, then look up in the chart below ...
(IMG:style_emoticons/default/bye1.gif) Andy
markb
post Jul 5 2008, 06:44 PM
914less :(
I think the problem is IIRC, the SC's have separate senders for the pressure & the idiot light. I'd like to find a sender that can do both.
Joe Bob
post Jul 5 2008, 07:12 PM
it's for an 82 SC gauge....and Mark is right, it's NOT a stock sender.
Getty's still out of business right? Somebody has done this and is running an SC gauge in a Getty Dash....
BTW, the idiot light works....if I need to plumb a pressure and temp sensor, that's fine. I just don't have the time for the R&R, I need to get this fixed and then ship the car.
I assumed the PO x 2 had done this....obviously that didn't happen....
markb
post Jul 5 2008, 07:59 PM
914less :(
The temp sender is in the standard taco plate. The problem I have with my triple gauge is I can either have an idiot light OR a pressure gauge. I'd like to find a sender that does both gauge AND light.
r_towle
post Jul 5 2008, 08:26 PM
Custom Member
Mike,
Contact Aaron, he did something like this.
Rich
computers4kids
post Jul 5 2008, 08:32 PM
Love these little cars!
Here's what the 911SC guy from the bird board sold me with his NOS gauge for my Ghetty dash. Won't swear it's correct...just going off his advice.
Joe Bob
post Jul 5 2008, 09:21 PM
That's a pressure and idiot light sender, which is what I'm looking for. Does it have a VDO serial number?
Temperture has to be supplied by a dipstick sender as the taco plate is NLA.
904svo
post Jul 5 2008, 09:52 PM
904SVO
VDO Dual sender units
VDO 360-006 = 0-80PSI for gauge 7PSI for light #30/2
VDO 360-023 = 0-150PSI for gauge 7Psi for light #30/23
Thread size is M10X1 on both
Hope this helps you
Joe Bob
post Jul 5 2008, 10:05 PM
How do you plumb it? Pipe thread and a splitter? Got a pic?
Duh, did a google, http://www.gettydesign.com/contact.html
904svo
post Jul 5 2008, 10:10 PM
904SVO
QUOTE(! @ Jul 5 2008, 08:05 PM) *
Jake at Aircooled has a flexable line on which it can be mounted or
you can get a M10X1 from a paintball gun store.
Joe Bob
post Jul 5 2008, 10:17 PM
hmmmm....back to square one.....
http://www.gettydesign.com/PDF%20Files/200...l%20Catalog.pdf
The catalog is all 911, Boxster, 996 and water pumper crap.....
904svo...thanks, for your help I'm looking for a SINGLE sender with dual outlet that runs BOTH the pressure and idiot light. I think the 30/2 will do it...
I have one for a VDO specific gauge in my Type I VW motor with a VDO gauge....what I need is the same that talks to a Porsche 911 SC Gauge, a little different.
hate to buy one and not know....Crap, I knew I'd be the first that missed Dave Sheppard's expertise.....he was up on this stuff....
I'll pull the trigger on Monday.
markb
post Jul 5 2008, 10:38 PM
914less :(
Mike, I think I have a taco plate on the core 2.0 at the shop.
Joe Bob
post Jul 5 2008, 10:43 PM
Very cool, that takes care of the temp.....gotta research the pressure and idiot light combo sender. Never assume that someone else took care of something. Check your email I sent you a link, thanks for your continuous help.
I'm going to contact "e gauges" on Monday. I need to get his settled prior to shipping the car up north.
markb
post Jul 5 2008, 11:13 PM
914less :(
Looks like this is the one we need.
Thanks 904svo!
Cap'n Krusty
post Jul 6 2008, 12:19 AM
Cap'n Krusty
QUOTE(! @ Jul 5 2008, 08:21 PM) *
The taco plate is NLA? Mark has some, and I have a new set. The SC had separate senders, and that's what you'll have to do. Furthermore, the sender for the gauge has a very large thread, and you're gonna have to make an adapter with the same thread as an axle nut. The Cap'n
Joe Bob
post Jul 6 2008, 01:08 AM
The temp sender is/was there...just not hooked up to the gauge in the dash...another duh.
The pressure sender comes in either 1/4 NPT or metric M10x1K ......if I remember correctly I have to plumb a hose to where the idiot light sender gets a read and connect this dual sender to the end....THEN I get a pressure signal 0-80 psi AND the minimum 7 psi at idle for the on/off idiot light signal....
RIGHT?
I'm thinking this is it.... $25 plus shipping....
link
(IMG:http://www.egauges.com/images/vdo/360-006.jpg)
But this can't be right because I'm an idjut....at least everyone thinks so.... (IMG:style_emoticons/default/blink.gif)
marks914
post Jul 6 2008, 10:37 AM
Guys,
Modern VDO gauge senders actually work backwards from the old ones. Its worth a shot, but I do not think its right.
Mark
- Lo-Fi Version Time is now: 2nd April 2026 - 02:54 PM
