hot summer days |
hot summer days |
minnesota loon |
Jul 6 2008, 10:44 AM
Member Group: Members Posts: 111 Joined: 30-September 07 From: white bear lake mn. Member No.: 8,173 |
Does the engine run cooler at high rpms or low rpms? My car runs just below the red line on the temp gauge. About in line with the m on the word temp. It stays fairly consistent at that point.
toon1 |
Jul 6 2008, 11:03 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
HIgher RPM's, to a point. 3200-3400 seems to be the sweet spot.
I don't notice huge diferences in the engine temps between summer and winter. Although summertime temps will not stablize as easy under load than winter. For all other normal driving conditions, they are about the same. |
hcdmueller |
Jul 7 2008, 01:35 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
The temp guage that came with the car is for oil temp. My 76 always seemed to be close to the same temp as yours. From what I have heard the 75 and 76 years tend to run a little hotter.
6freak |
Jul 7 2008, 08:48 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
ericread |
Jul 7 2008, 08:53 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
OK, we have two opinions here. Toon1 says that 3200-3400 rpm is the sweet spot. My 74 2.0L FI system seems to run coolest at between 3200 and 3400 rpm also.
ncdmueller; You mention that higher revs generate additional heat. Do you consider 3400 rpm "higher revs" or are you talking about revs over 3500 rpm? Anybody else want to chime in here? Eric Read |
Root_Werks |
Jul 7 2008, 09:39 AM
Village Idiot Group: Members Posts: 8,337 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
There are reeeeeealy tiny little tiny small little numbers on your temp gauge just out of sight unless you look at it from the side. Get a flash light and have a look. Most find the begining of the red section is only 240 degrees.
Oil doesn't even boil out moister until it hits 210 which is where you want it to run. |
Lo-Fi Version | Time is now: 11th June 2024 - 05:46 AM |
