drawbardude |
drawbardude ![]() Group: Members Posts: 8 Joined: 25-January 06 From: Bremerton, WA Member No.: 5,477 ![]() |
Arggh! Does anyone have a suggestion on my fuelish problem. I couldn't get my 1970 - 1.7 L car started so looked at the fuel lines for the problem. Long story short - I replaced the lines - yeah. After replacing the lines, car started easily and ran for 5 minutes. Now, it won't start again, it would appear I have a fuel lock - or perhaps a brain lock. Any suggestions out there.... (IMG:style_emoticons/default/ar15.gif)
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
need more input. FI or carbs? Is the fuel pump running?
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
did you pull the tank and replace those? they are easy to kink.
mike |
rebelmdot |
914ini ![]() ![]() Group: Members Posts: 224 Joined: 25-January 08 From: Tennessee Member No.: 8,625 Region Association: South East States ![]() |
did you replace or clean the fuel filter? I would look to the filter or fuel pump for culprit.
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
There is a whole host of things that could have gone wrong during the replacement. You can't just guess at this stuff you have to troubleshoot methodically. Like Curt said is this FI? assuming it is ...
Is the fuel pump working? (quick buzz when key first turns on) Is it doing its job? Gross test. After the system is pressurized turn the key off and remove the fuel pressure plug on the drivers side rail - even with the pump off you should get a squirt of fuel. Proper test is to insert a fuel pressure guage. Do these two first - could save you a whole bunch of time farting around. |
Lo-Fi Version | Time is now: 11th July 2025 - 05:17 AM |
