Fuel pressure...doesn't seem like it's enough? |
computers4kids |
Jul 21 2008, 02:30 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
My 75 has the fuel pump in the front trunk with a carb fuel pump ( I think faucet)...anyway, I had placed an adjustable regulator on my carbed V-8 thinking I would need to bump the pressure down. The Eldebrock carb suggests 5lbs of pressure. My pump is only cranking out 2.5 lbs with no regulation. Is that enough pressure or do I need to address the issue? If so, do you think I have a pinched line or just a cheap pump?
Thanks ahead of time... |
messix |
Jul 21 2008, 02:32 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
nope, step up to a real fuel pump.
computers4kids |
Jul 21 2008, 02:37 PM
messix |
Jul 21 2008, 02:42 PM
go to jeggs or summit and they have good street pumps for under $100.
do check for a fuel line kink. but those facet pumps wont run a healthy v8, it'll run you dry on any good foot to the floor run. they work ok as a helper pumb or crutch. or on (IMG:style_emoticons/default/happy11.gif) a little 2.0L vw motor |
messix |
Jul 21 2008, 05:05 PM
one more thing... you should wire it up so the oil pressure sender/swiwtch will shut the fuel pump down if you loose oil pressure. this can save your car from fire in an accident.
Lo-Fi Version | Time is now: 9th June 2024 - 07:44 AM |
