Optima - The only true 914 cancer abatement option?, But how do you charge them? |
jesiv |
Jul 24 2008, 10:40 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Ok, so I my optima totally died (IMG:style_emoticons/default/WTF.gif) . It was sad (IMG:style_emoticons/default/sad.gif) .
What and how do you charge your red top? What is the best charger for the optima? Regards, James |
Joe Bob |
Jul 24 2008, 10:44 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
The digital chargers suck.....my old Sears analog rocks.
SirAndy |
Jul 24 2008, 10:47 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
how do you charge your red top? I have used electricity in the past with good results! (IMG:style_emoticons/default/beer.gif) Andy |
ws91420 |
Jul 24 2008, 10:48 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
You are supposed to use a charger rated for AGM batteries. If you dont want to buy one if you take it somewhere to charge it make sure they use that type of charger or you will most definitely kill it.
jesiv |
Jul 24 2008, 11:22 PM
how do you charge your red top? I have used electricity in the past with good results! (IMG:style_emoticons/default/beer.gif) Andy Andy Are you implying that I should actually plug a 914 (much less mine) into the USA electrical network grid? (IMG:style_emoticons/default/WTF.gif) I am very concerned with the potential consequences of such a real time connection (IMG:style_emoticons/default/dry.gif) . I am prepared to plug a 914 into the network buffered by a charger (IMG:style_emoticons/default/piratenanner.gif) … The question is which one (IMG:style_emoticons/default/drunk.gif) ? Regards, James |
Rand |
Jul 24 2008, 11:55 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I didn't think the Optima red top took anything special. (IMG:style_emoticons/default/confused24.gif)
I run my car enough that the alternator keeps it up. If it was too low to crank I would jump start it. If I wasn't going to run it long enough to replenish naturally or it was low, then I would use a basic trickle charger made for car batteries. If it is going to sit a long time without running (like months over the winter) then maybe a battery tender to keep it topped off. |
ws91420 |
Jul 25 2008, 12:20 AM
HERE is a link to a page for reccomendations to charging an OPTIMA
OPTIMA SITE CHARGING GUIDE This post has been edited by ws91420: Jul 25 2008, 12:29 AM |
roadster fan |
Jul 25 2008, 03:11 AM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
Hey James,
Looks like the link to the Optima recommended charging procedure is what I do for regular lead acid batteries. If it died and early death maybe just a lemon. BTW, missed seeing you up in Scotts Valley at Canepa Design on Saturday. We should plan another bay area owner's trip there before the 914/6GT sells. Sorry for the quick hijack good luck with your battery. Jim |
hcdmueller |
Jul 25 2008, 04:13 AM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
I let my red top sit for 9 months and it was down to 8 or 9 volts. I used my motorcycle charger to get it back up to 13 or so. It is only 1/4 amp and it took just over a week. The battery is fine and I have not had a problem with it since.
kerensky |
Jul 25 2008, 03:50 PM
Senior Member Group: Members Posts: 531 Joined: 1-February 06 From: Norman, OK Member No.: 5,508 Region Association: Southwest Region |
If I wasn't going to run it long enough to replenish naturally or it was low, then I would use a basic trickle charger made for car batteries. If it is going to sit a long time without running (like months over the winter) then maybe a battery tender to keep it topped off. Every time I see this topic come up I toss in my usual warning. Trickle chargers and battery tenders seem to be OK for use, but do not use a regular car battery charger on your (stock) 914 without disconnecting the battery. This can and will fry your fuel injection ECU. I went thru two that way. (IMG:style_emoticons/default/headbang.gif) |
Rand |
Jul 25 2008, 05:59 PM
Good point Chad. I always do pull the battery out before putting it on a charger.
(IMG:style_emoticons/default/beerchug.gif) Actually I started the habit years ago (before I used Optimas) of setting the battery outside on the ground, because of the off chance the lead-acid batteries could boil over and leak acid while charging. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:48 AM |
