Anti-sieze, or grease? |
Elliot Cannon |
Jul 28 2008, 07:29 PM
What's best for axle slpines? Grease or anti-sieze?
Attached image(s) |
PeeGreen 914 |
Jul 28 2008, 07:45 PM
Generally nothing. If you put anything it should just be grease. Anti sieze is only for nuts and bolts that won't see high heat. It turns into glue and does the opposite of what it is supposed to do.
ArtechnikA |
Jul 28 2008, 08:02 PM
What's best for axle slpines? Grease or anti-sieze? So here's an alternate opinion... Moly disulphide antisieze is already basically a dry lubricant. I've use that on lots of ur-GTI axles and when I was autocrossing I was replacing front bearings every couple of events. LubroMoly also makes a hi-temp copper-based antisize I'd have no heartburn using. Use a synthetic grease or Swepco 101 if you're using grease, IMO... |
HAM Inc |
Jul 29 2008, 09:26 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
Moly based anti-sieze. That application begs for it! I use it on the axle nut when torqueing too.
6freak |
Jul 29 2008, 10:00 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
What's best for axle slpines? Grease or anti-sieze? Clean!!! and then grease! ..Lubemaster heavy duty NLGI#2..It contains moly.prevents corrosion good for heavy loads and pressure has a wide temp range 0-400d f and is water resistant....its moveing parts they need some kind of lube or they will just turn to black metal dust ........And remember certain grease`s are NOT compatable..This one is NOT GOOD with clay or bentonite grease`s......Like we say in the Crane world lube it or loose it...J.M.O hope this helps |
ArtechnikA |
Jul 29 2008, 10:18 AM
6freak |
Jul 29 2008, 10:27 AM
...its moving parts they need some kind of lube... hub splines are only moving parts when you R&R the hubs. You do need something to make sure you prevent corrosion and galling. O they move you just dont think so! there not an interferance fit so there is slope there and if you dont lube them you will have lots of slope...... thats not what you want ....Again JMO |
jd74914 |
Jul 29 2008, 12:28 PM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Slope? I'm confused on what you are trying to say.
The point of splines is to not move. |
6freak |
Jul 29 2008, 01:05 PM
Slope? I'm confused on what you are trying to say. The point of splines is to not move. My bad Slop! you are correct .But they do just enough to cause wear.this is not an interference fit so there is some play in it or slop if you will.Hence forth and there for you need lube...Jmo once again .i just know i would use something there and would not run them dry...you wouldnt run gears dry would you and thats all they are ...Hope that helps (IMG:style_emoticons/default/smile.gif) |
r_towle |
Jul 29 2008, 01:57 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I would suggest that after you clean it you apply a fresh coat of pepperoni pizza drippings directly to the spline.
The protein enriched pepperoni juice will guarantee that is never siezes up on you. Rich |
6freak |
Jul 29 2008, 03:45 PM
I would suggest that after you clean it you apply a fresh coat of pepperoni pizza drippings directly to the spline. The protein enriched pepperoni juice will guarantee that is never siezes up on you. Rich well i guess the pro`s will chime in and they can set use all strait ..i just know i would not put it back togather without some kind of grease in there (IMG:style_emoticons/default/smile.gif) |
dbgriffith75 |
Jul 30 2008, 01:26 PM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
QUOTE i just know i would not put it back togather without some kind of grease in there (IMG:style_emoticons/default/agree.gif) Whether it's intended to be a moving part or not, when there's steel against steel... or I guess I should say metal against metal... there should be some type of lubrication. To prevent siezing if nothing else. In this case, as 6freak pointed out, there is just a small amount of slop in the splines. So clean it & grease it- besides, it will aid in the future if you ever need to remove the axle again. |
Lo-Fi Version | Time is now: 3rd June 2024 - 04:37 AM |
