914fun |
Member ![]() ![]() Group: Members Posts: 108 Joined: 22-June 08 From: Joplin MO Member No.: 9,201 Region Association: Southwest Region ![]() |
Why is the floor pan so irregular? Even with padding wont my carpet show these dips and bumps in the floor pan over a short piriod of time? How do you guys make it look flat? Maybe a thick foam, but what kind to use that will not show the dips and bumps after while? (IMG:style_emoticons/default/confused24.gif)
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
A flat panel isn't as strong/stiff. Those irregularities are needed to resist flexing.
Don't worry about it showing through any decent carpet. Not an issue. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
A flat panel isn't as strong/stiff. Those irregularities are needed to resist flexing. Don't worry about it showing through any decent carpet. Not an issue. (IMG:style_emoticons/default/agree.gif) The ribs are added for additional rigidity. With good carpet, it won't be a problem ... (IMG:style_emoticons/default/bye1.gif) Andy |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
coco mats
914fun |
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,852 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
$200 Seems like a pretty expensive carpet kit; where did you get it from?
914fun |
$200 Seems like a pretty expensive carpet kit; where did you get it from? They are on ebay. The carpet starts out much cheeper but i Went with the loop at 180.00 after shipping it came to 195.00. Not much of a backing on it. Dont think it will last long. The spot that worries me the most is the 2 inch diameter round spots by the feet Its like 3 levels higher than the lowest point of the floor pan. Anyway I just thought the car might be missn somthing. But if this is normal ill just deal with it. Thanks guys. |
southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
I have the same carpet kit and it is of high quality. I believe the same company sells a plastic covered padding kit for the cockpit. You may have to look at their ebay store to find it.
Steve |
Lo-Fi Version | Time is now: 11th July 2025 - 02:53 PM |
