| Joseph Mills |
Jan 30 2004, 01:13 PM
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Not that there is anything wrong with Paragon. I believe they "order" the higher rates. I'd just like to shop around a bit.
I'm looking for 2.5" inner diameter, non-progressive, 225#. Seems Pelican only offers 180#. There must be other distributors with a wide range of selection. Or even better maybe someone on this board? (IMG:style_emoticons/default/beerchug.gif) |
| fiid |
Jan 30 2004, 01:19 PM
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,828 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I got my springs (Eibach coilovers with adjustable perches) from Ground Control on brad's recommendation. I like them a lot, and my ride height is nice and low now.
(IMG:style_emoticons/default/smilie_pokal.gif) |
| machina |
Jan 30 2004, 01:31 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 |
the springs are standard race items from hypercoil, eibach, etc. You can order them pretty cheap from coleman race products. Most of the "kits" available use springs and hats from coleman.
http://www.colemanracing.com/prodex/cat.ht...?cat=SUSPENSION most race parts supply houses stock them. dr |
| cork |
Jan 30 2004, 01:33 PM
ground zero ![]() Group: Members Posts: 49 Joined: 11-January 03 From: phoenix,az Member No.: 132 |
I've got #250.
| Joseph Mills |
Jan 30 2004, 02:17 PM
QUOTE(synthesisdv @ Jan 30 2004, 01:31 PM) the springs are standard race items from hypercoil, eibach, etc. You can order them pretty cheap from coleman race products. dr DR - Thanks for the URL....Coleman looks good. I know I need 2.5 ID, but can't remember....do I need the 8" or 10"? (IMG:style_emoticons/default/confused24.gif) Hey thanks Cork. Do you mean for sale? |
| machina |
Jan 30 2004, 02:43 PM
you need to set your car at ride ht and measure. I think either one will work but it depends on your shocks, setup, etc.
dr |
| rdracrdave |
Jan 30 2004, 03:10 PM
Newbie ![]() Group: Members Posts: 34 Joined: 5-May 03 From: Cincinnati,Ohio Member No.: 653 |
I usually buy coilover springs from Jegs , The dragracer guys .
They have good prices and selection and usually ship quickly . The brand that they carry is QA-1 , The same co. as the shock mfg. They carry a much larger selection than their catalog or website lists , so just call and ask the order guy for what you want. Coleman is a good source for coilover kits as is Day Motorsports in Texas.Both have websites to reference . I use a 10" Spring on the rear of my 914 GT2 racer , so that should give you a starting point. Good luck Dave |
| cork |
Jan 30 2004, 08:13 PM
Yes, I'm at work, I can tell you more about them on saturday, but they may be the same as Colman's. To stiff for my car I just wanted the coil over parts.
| campbellcj |
Jan 30 2004, 10:36 PM
I can't Re Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,703 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California
Coleman, Hoerr and Pegasus all carry the Hyperco springs for around the same price.
| KenH |
Jan 31 2004, 10:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
GPR in San Luis Obisbo has H&R at good pricing.
I used 10.5" but they could have been a bit longer. Ken |
| BIGKAT_83 |
Jan 31 2004, 11:09 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,800 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States
Try Afco racing. I got a set of 225lb springs on sale last summer for $25 each
Bob (IMG:style_emoticons/default/wink.gif) http://www.secureperformanceorder.com/afco...3&CategoryID=17 |
| rhodyguy |
Jan 31 2004, 11:25 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
coleman's breather tank with the petcock is pretty neat!! i wonder what size the inlet fitting is? that could be a nice unit for carbed cars if the inlet worked with the hose for the oil fill tower.
kevin |
Lo-Fi Version | Time is now: 10th March 2026 - 04:37 AM |
