Oh the things PO's do..., bad day with the 914 |
biosurfer1 |
Aug 4 2008, 10:15 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
PO: Derrrr, I don't feel like fixing the battery tray correctly Earl, what do you think I should do??
Earl: Duhhh, why dont you just put this steel thing on there and glue it into place?? PO: Uhhhh, but the glue isn't holding!! Maybe I'll just screw it into the body! (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) (IMG:style_emoticons/default/mad.gif) |
biosurfer1 |
Aug 4 2008, 10:18 PM
I guess I'm just pissed because I found this rust...some of it is ok (suprisingly the longs are solid)...other areas had wonderful holes (IMG:style_emoticons/default/mad.gif)
biosurfer1 |
Aug 4 2008, 10:22 PM
I'm guessing the PO did put Por-15 or something else on the longs because I hit them with a wire wheel for quite a bit and couldn't get past the black stuff under the surface rust ("OK" areas) so thats good, but the other panels will have to be replaced.
I thought about just taking a wire wheel to everything and spraying Por-15 and not messing with it but I can't live with holes so I'm just taking it to a professional. Anyone know of a good welder in the Roseville/Sacramento area that can do this? Would prefer a mobile guy since the motor is out but I could probably find a trailer to haul it someplace (Napa is just too far)...I just want to get it back on the road!! |
3d914 |
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
Brett, I feel your pain man.
championgt1 |
Aug 4 2008, 11:14 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
glued and screwed..........................classic!
biosurfer1 |
Aug 4 2008, 11:30 PM
I just dont get it, a new battery tray and support is not that expensive or hard to replace, but instead people decide to do this...
very frustrating |
watsonrx13 |
Aug 5 2008, 06:21 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
I just dont get it, a new battery tray and support is not that expensive or hard to replace, but instead people decide to do this... very frustrating Here's a link to my website showing what the PO did with a new battery tray and stand.... (IMG:style_emoticons/default/blink.gif) -- Rob |
biosurfer1 |
Aug 5 2008, 10:03 AM
geeze, whats with PO's and band-aid repairs?!?
Wes V |
Aug 5 2008, 12:06 PM
Member Group: Members Posts: 482 Joined: 11-October 07 From: Los angeles Member No.: 8,211 |
I think there should be a "PO Hell" string.
Other than venting, it would actually serve the purpose of letting potential buyers know what to look for! Wes |
IronHillRestorations |
Aug 5 2008, 01:28 PM
I. I. R. C. Group: Members Posts: 6,724 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
biosurfer1 |
Aug 5 2008, 01:33 PM
Perry,
I saw that thread and thus the reason I'm not going to try and fix this myself. I have welded before but just for a while in one of my college classes, and none of it looked pretty. I'm sure I could manage something, but it would look like crap and probably not be correct and I HATE fixing things twice. Now the trouble is finding a guy to do this work at my house since the engine is already out. Finding a welder:easy...finding an automotive repair guy:easy...finding a guy who can weld rust repair on a 914:not so easy:( |
Aug 5 2008, 01:41 PM
With a gas MIG welder and some practice you could do a good repair.
The main thing about welding this kind of repair is the practice, and then patience to not go too fast. Also good prep work, and careful fitment of your repair pieces. |
Wes V |
Aug 5 2008, 03:47 PM
Also good prep work When doing this sort of thing, it's ALL in the prep work!!! You can't weld to rust!!! (BTDT) It HAS to be shiny metal. You can't weld to POR15! It's even a pain in the ass to weld to "weld-through" primer (it doesn't like to start the arc). (if I'm doing a rossette weld, I scratch off the primer with a dental pick before hand) If you trust me on these points, you will do fine. Wes |
Lo-Fi Version | Time is now: 2nd June 2024 - 01:08 AM |
