Fresh Air Blower Motor Brushes, Anybody have them?? |
AvalonFal |
Aug 13 2008, 07:24 AM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Does anyone have or know where I can find fresh air blower motor brushes?? Finally got the motor running, but 1 brush is broken into 2 pieces and the other is down to about 1/2 size. Any help greatly appreciated.
Paul |
jea69 |
Aug 13 2008, 12:02 PM
doing unspeakable things to iron Group: Members Posts: 51 Joined: 13-March 08 From: norway Member No.: 8,811 Region Association: Scandinavia |
im shure you will get a replacement, but failing that you could get some oversized ones and just file them to fit ,did that alot in my vintage motorcycle aera (IMG:style_emoticons/default/beerchug.gif)
Katmanken |
Aug 14 2008, 07:41 PM
You haven't seen me if anybody asks... Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Try Sears or a real hardware store. My Sears tool store has a tray of assorted brushes. If you can't find the one you need, buy closest oversize and file the carbon down. It's soft, easy, and messy at the same time.
If it's generator brushes for a VW beetle, you drill a hole in the side, push the old wire braid through and secure with solder. Ken |
AvalonFal |
Aug 15 2008, 08:35 AM
Try Sears or a real hardware store. My Sears tool store has a tray of assorted brushes. If you can't find the one you need, buy closest oversize and file the carbon down. It's soft, easy, and messy at the same time. If it's generator brushes for a VW beetle, you drill a hole in the side, push the old wire braid through and secure with solder. Ken Thanks for the Sears tip. The fresh air motor brushes are fairly small - about 5mm x 6 mm. I just looked at over 600 brushes on Amazon.com, but none the exact size. So filing larger ones down is probably the quickest way to get this thing done with. Paul |
Lo-Fi Version | Time is now: 10th June 2024 - 01:05 PM |
