foglight wiring |
foglight wiring |
fergus1 |
Aug 13 2008, 02:32 PM
Newbie Group: Members Posts: 1 Joined: 13-August 08 From: mission viejo, CA Member No.: 9,418 Region Association: Southern California |
Hello everyone!
I'm kinda new here to the site and I have a question for the electrical people. My 914 did not have fogs when i bought it but it does have the wiring for them, i think (the extra wires that come out with the horn wiring?). I have a set of lights that i bought from camp914 and I'm now trying to install them. Where do the wires come out inside the car? Do I need to unscrew the fuse block? What color are the wires? I've tried to follow the diagram in the Haynes manual but with no luck. I'd also like to use a factory looking switch if not the real thing. Any help would be much appreciated. Thanks, Kirk Ferguson |
Joe Ricard |
Aug 13 2008, 04:25 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Basically you only need the switch.
under the dash far left near head light switch there should be 2 wires one purple and one black not connected to anything. This actuates a relay that the other end of the white with yellow striped wires go to. I have a switch that I will sell you cheap if you want. |
914Sixer |
Aug 13 2008, 08:06 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will have to pull down the fuse block and add a relay in the vacant holder in addition to the switch. Switch wires will be below the combo guage. Grey/red stripe is power, black/blue is light and brown to ground.
Joe Ricard |
Aug 14 2008, 06:04 AM
As you can see not all cars are exactly the same.
Or my feeble memory can't reach back 5 years ago. (possible) |
SGB |
Aug 14 2008, 07:21 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
You remember FIVE years ago? I don't even remember this morning!
Mark Henry |
Aug 14 2008, 07:23 PM
Try doing a search, Demick had a good how to on the wiring hook up, I did mine so it just works with the switch (stock it works with the low beams only)
I use mine for daytime running lights. The switch is the same as the 914 defog switch and also it's a common early VW bug emergency 4-way lights switch, the only thing "special" is the insert in the knob. |
Lo-Fi Version | Time is now: 11th June 2024 - 12:17 AM |
