Where to put O2 sensor?, Where to put the sensor if using stock muffler |
Joe Owensby |
Aug 13 2008, 07:43 PM
JoeO Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States |
I need to upgrade my muffler. Now have a Monza, with a few very small holes. I plan to put in an AF ratio meter, and add a closed loop FI controller. Where would be the best place to put the O2 sensor on a stock muffler?? I was thinking of going to either a stock muffler, or a Bursch. I don't want too much noise. It looks as if with the Bursch, I could use one in the collector area. How loud are the Bursche versus factory 2.0 muflers? Thanks for the help. JoeO
Joe Bob |
Aug 13 2008, 07:47 PM
I need to upgrade my muffler. Now have a Monza, with a few very small holes. I plan to put in an AF ratio meter, and add a closed loop FI controller. Where would be the best place to put the O2 sensor on a stock muffler?? I was thinking of going to either a stock muffler, or a Bursch. I don't want too much noise. It looks as if with the Bursch, I could use one in the collector area. How loud are the Bursche versus factory 2.0 muflers? Thanks for the help. JoeO Best to have it just prior to the single inlet of the muffler. If you have a dual inlet muffler, you only read half the exhaust.... |
jcd914 |
Aug 13 2008, 08:17 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
O2 Sensors don't work well cold. If you are putting it that far from the engine you should use a heated (3 wire) O2 sensor. Jim |
Lo-Fi Version | Time is now: 11th June 2024 - 12:01 AM |
