| jnp914 |
Jan 31 2004, 06:08 PM
Member ![]() ![]() Group: Members Posts: 177 Joined: 19-August 03 From: Las Vegas, NV Member No.: 1,046 |
The release cable for the front trunk latch, along with that POS pot metal threaded handle, went TU. A quick perusal of the catalogs does not show any availble for the 914, but both the inner cable and handle are listed for the 911 and at a very inexpensive price.
Will the 911 cable and handle fit? |
| Eric_Shea |
Jan 31 2004, 07:11 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I just took mine off while installing the GT Oil Cooler Shroud. It's off a 74. Need one?
| jnp914 |
Jan 31 2004, 08:20 PM
oh, OH! Gimmee!!!!
Sandy, Ut, huh? I graduated from Weber State. |
| echocanyons |
Jan 31 2004, 10:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,119 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
QUOTE I graduated from Weber State. ]You mean Harrison High school? (IMG:style_emoticons/default/wink.gif) Me too, then went on to UofU |
| Eric_Shea |
Feb 1 2004, 02:54 PM
I won't hold that against either one of you (IMG:style_emoticons/default/laugh.gif)
Tis your's... e-mail me your address. Got anything I need? |
| andys |
Feb 1 2004, 03:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None
Speaking of the front trunk release, mine is hugely difficult to pull. The latch itself is fine (disassembled, cleaned, lubed, works fine), and the cable pulls very easily when disconnected from the latch. When the two are hooked together, it's difficult to pull again. Doesn't matter whether the trunk is open or closed. Everything *appears* to be in order.....any secrets?
Thanks, Andy |
| seanery |
Feb 1 2004, 03:59 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Look to see if the plastic housing is broken/cracked anywhere. Mine is that way and it's a hard pull (and doesn't spring back correctly). Look in the unexposed places too.
| Eric_Shea |
Feb 1 2004, 04:41 PM
Boxed and ready to go...
I have the plastic tube seperate if someone needs that. E. |
| seanery |
Feb 1 2004, 04:54 PM
Is it flexible?
| Eric_Shea |
Feb 1 2004, 04:56 PM
QUOTE Is it flexible? Kinda sorta... |
| jnp914 |
Feb 1 2004, 06:40 PM
ummm...did this conversation just change direction or what?
perverts |
| FlatSix |
Feb 2 2004, 07:07 AM
English Member ![]() ![]() Group: Members Posts: 191 Joined: 14-January 03 From: Poole, England Member No.: 144 |
QUOTE Speaking of the front trunk release, mine is hugely difficult to pull. I have exactly the same trouble. There was a tech article a while ago (maybe on the PP board). I followed that and it made a very tiny difference, but it did not solve the issue. Everything works well on it's own. Close the front trunk and then try to pull the handle... as andys said. Is this common? |
| roundboy914 |
Feb 2 2004, 07:31 AM
Member ![]() ![]() Group: Members Posts: 210 Joined: 16-October 03 From: Chicago, IL Member No.: 1,251 |
Hey,
I got a question also. When i close my front hood, the latch doesn't keep the hood down. The handle is also hard to pull, and you have to push it back in after opening. At any rate, to get the hood to stay down, you have to keep pushing on the front deck lid, and hope that it finally catches. Is there an adjustment that i am missing? |
| seanery |
Feb 2 2004, 07:50 AM
roundboy, it sounds like mine. after you pull the cable release and the trunk pops, push the cable back in and try it. That works for me until I can get a new cable and housing.
| TheCabinetmaker |
Feb 2 2004, 08:20 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Sounds like a broken spring on the latch. I've also seen them bend.
Roundboy, have you adjusted the latch? could be a tad too low? My cable got progressively harder to pull and one day it finally let go. After removing the front bumber. I found a very dirty latch mecanism, and the spring had come loose jamming the latch. Took it apart, cleaned, reasembled, relubed and its worked great every since. Realigning the hood was a matter of trial and error |
| Eric_Shea |
Feb 2 2004, 09:15 AM
I have the latch available too.
The hard pull problems sound like the catch may be too tight against the latch... (IMG:style_emoticons/default/confused24.gif) (latch seems to work fine w/o the catch engaged) try moving the catch to one side or the other. Watch while you close the hood and see if it is over to one side more than the other... just guessing at this point. Or - get a fiberglass hood with hood pins. Take the latch, cable and handle out of the car (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 22nd October 2026 - 06:30 AM |
