| Doug73/2.0 |
Feb 3 2004, 11:42 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 5-November 03 From: Boston mass Member No.: 1,312 |
Richard located a 914 that's only an hour away (amazing :-)
It been stored 6 years indoors. Other than checking the oil and obvious stuff, Is there anything I should do before seeing if the engine will turn over? Do I need to drain out the old gas first just to see if it has not siezed? Love to see if it runs during the visit. I have Patrick Paternie's book so I'm reasonably comfortable where to look for rust. If it is a keeper I'll trailer it home. Thanks Doug |
| Air_Cooled_Nut |
Feb 3 2004, 12:04 PM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
I hope the gas was COMPLETELY drained before it was parked (highly doubt it, though) otherwise you get the unpleasant task of having to clean the entire fuel system (IMG:style_emoticons/default/sad.gif)
Easiest way would be to put it in second or third gear and push the car. If it rolls then it's not seized. |
| RocknRollFrenzy |
Feb 3 2004, 12:06 PM
Member ![]() ![]() Group: Members Posts: 94 Joined: 3-November 03 From: Santa Cruz, CA Member No.: 1,305 |
mine had been sitting for about 2 years.......added a little fresh oil and a new battery and it fired right up within a few seconds.....your results may vary.
| otto |
Feb 3 2004, 12:08 PM
Member ![]() ![]() Group: Members Posts: 158 Joined: 21-August 03 From: Venice, CA. Member No.: 1,056 |
If it FI you need to flush the tank.Change the oil to a 30wt. Remove the Spark plugs, Fill cylinders with light oil and let it sit over night. When you are ready to turn motor over put the car in 5th gear and push car backwards to purge the oil out of the cylinders. Then hook up the battery and spin it over with the plugs still out. If it spins freely, put the plugs in and check for spark at the dizzy by opening the points. If you have spark and Fresh Gas in the flushed tank you are ready.Steve
| Porsche Rescue |
Feb 3 2004, 12:10 PM
Saving and Enjoying Old Porsches ![]() ![]() ![]() ![]() Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
Another method: remove the spark plugs, use a wrench on the alternator pully while pressing down on the belt with your other hand or use a socket on the crank pully. If it turns over freely, squirt some oil in each cylinder (I use Marvel Mystery oil in a little squirt can and a short piece of tubing to get it in the spark plug hole). Then use starting fluid if you can't get gas to the FI/carbs and see if it will fire.
Edit: Steve posted while I was typing. I should have also suggested to turn it over with the starter while the plugs are out. |
| maf914 |
Feb 3 2004, 01:07 PM
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None
Drain the old fuel before trying to start the car on its own. The tank is probably full of rust sediment which will be drawn into the pump and sent to the FI or Carbs, before the pump chokes and dies from blockage. After draining the fuel take the tank out, not difficult, and have it flushed. This is a good time to replace the fuel lines in the front compartment.
My car was garaged for seven years. The above suggestions are based on my experiences! (IMG:style_emoticons/default/ohmy.gif) Mike BTW, the seven year old fuel was distributed between a couple of old pickups and lawn mowers. They all seemed to run okay. |
| mike_the_man |
Feb 3 2004, 02:15 PM
I like stuff! ![]() ![]() ![]() Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
Watch for fuel leaks, and have a fire extinguisher handy, just in case. Old fuel lines can crack. Or better yet, replace all the fuel lines as previously suggested.
| tat2dphreak |
Feb 3 2004, 02:20 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
not exactly 914 experience... but here's what I did/would do: pull the tank, clean it out good... when you put fuel in it again, also add a can of B12 Carb cleaner... inspect all of the lines or replace as already suggested...
just my .0190.. 2 cents aren't worth as much as they used to be (IMG:style_emoticons/default/smile.gif) good luck! |
| Steve Thacker |
Feb 3 2004, 03:04 PM
UMMMPH Yea Baby Yea ! UMMMPH ![]() ![]() ![]() Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
QUOTE(otto @ Feb 3 2004, 02:08 PM) If it FI you need to flush the tank.Change the oil to a 30wt. Remove the Spark plugs, Fill cylinders with light oil and let it sit over night. When you are ready to turn motor over put the car in 5th gear and push car backwards to purge the oil out of the cylinders. Then hook up the battery and spin it over with the plugs still out. If it spins freely, put the plugs in and check for spark at the dizzy by opening the points. If you have spark and Fresh Gas in the flushed tank you are ready.Steve (IMG:style_emoticons/default/agree.gif) When I found my 2.0 engine that had been setting outside for 9 years. The only thing I did differently, was shoot a good amount of PB Blaster to the cylinders. I prefer this over oil. I replaced the rear main seal also because it was out of the car at the time,...hard as a brick it was. |
| Doug73/2.0 |
Feb 3 2004, 03:51 PM
Thanks everyone...The advice is much appreciated. The basic theme seems do be don't go firing it up with the old gas sitting in it.
So it sounds like just making sure the engine is not siezed is the best I can do before plunking down $$ and bringing her home (IMG:style_emoticons/default/huh.gif) . Once home I'll follow the sugestions. Thanks (IMG:style_emoticons/default/smile.gif) |
| Jeffs9146 |
Feb 3 2004, 04:12 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE The only thing I did differently, was shoot a good amount of PB Blaster to the cylinders. If you use PB change the oil after it starts! Jeff |
| Eric_Shea |
Feb 3 2004, 06:21 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
| Mark Henry |
Feb 3 2004, 08:40 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
My teen was in storage for over ten years, I did all of the above and the thing would not start. Checked all of the nomal stuff still no go.
Yanked the injectors, 3 were seized, stuck in 3 good used ones and varoom! |
Lo-Fi Version | Time is now: 16th March 2026 - 01:46 AM |
