idle and alternator, couple questions |
statesblue |
Sep 5 2008, 01:26 PM
Newbie Group: Members Posts: 24 Joined: 4-August 08 From: Chino Valley Az Member No.: 9,386 Region Association: Southwest Region |
I have a 75 with a 1.8 fuel injected motor. When I first start it it seems to stumble all over itself and runs on 2 cyl. til I wind it up a few times and clean it out. Then it seems to have a little trouble keeping an idle. Once it is warmed up it runs just fine. Are these cars that cold blooded or is there a problem I can correct?
The other thing is the alternator light stays on sometimes for a couple blocks then goes out. Is this normal or is there a problem brewing? |
Bartlett 914 |
Sep 5 2008, 02:03 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have a 75 with a 1.8 fuel injected motor. When I first start it it seems to stumble all over itself and runs on 2 cyl. til I wind it up a few times and clean it out. Then it seems to have a little trouble keeping an idle. Once it is warmed up it runs just fine. Are these cars that cold blooded or is there a problem I can correct? The other thing is the alternator light stays on sometimes for a couple blocks then goes out. Is this normal or is there a problem brewing? My 1.8 runs pretty good when cold. I know I can make it better. You have some issues that need to be addressed. One may be the alternator belt. If this is loose, it can cause both of your problems. The belt can slip then grab then slip etc. Check your belt first then look into the AAR valve and other engine issues for your poor cold running issues.. |
Lo-Fi Version | Time is now: 23rd May 2024 - 12:34 AM |
