Venturi Removal Trick - HELP, Can they be removed with the carbs installed? |
vesnyder |
Sep 13 2008, 07:44 AM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
I am trying to replace my Weber venturis - I removed all the top components of the carbs while they are still installed on the car. Now I am trying to remove the venturi's and I cannot get any leverage on them? Is there a trick to getting these out or should I just remove the entire carb and push the venturi out from the motor side?
Thanks! |
lotus_65 |
Sep 13 2008, 07:52 AM
Senior Member Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region |
I am trying to replace my Weber venturis - I removed all the top components of the carbs while they are still installed on the car. Now I am trying to remove the venturi's and I cannot get any leverage on them? Is there a trick to getting these out or should I just remove the entire carb and push the venturi out from the motor side? Thanks! for sure, you should be able to ease them out without pulling the carbs. did you miss the set screw on the side? there's a screw you need to loosen, but then you should be able to reach in with a finger or 2 and pull them. maybe a squirt of pb blaster or wd around the edge... paul |
Cevan |
Sep 13 2008, 07:54 AM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
There's a set screw on the back side of the carb that holds the venturi in place.
Lo-Fi Version | Time is now: 6th June 2024 - 07:48 PM |
