how to get the front bumper off? |
terrymason |
Sep 14 2008, 06:35 PM
Member Group: Members Posts: 346 Joined: 23-November 05 From: Virginia Beach Member No.: 5,174 |
Hey guys, anyone know how to get the front bumper off my 74? I've stared at it for a while, and just can't figure it out.
Midtowner |
Sep 14 2008, 06:45 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
If it's like my 1973, then there should be two 13mm bolts inside each wheel well - one higher in the body and one lower. Each about four inches apart. Always helps to turn the wheels all the way to one side. Before you remove the bumper, I recommend getting something high enough to reach the bottom side of the bumper to support it during disassembly. (IMG:style_emoticons/default/smile.gif)
hitbyastick |
Sep 14 2008, 06:47 PM
Newbie Group: Members Posts: 37 Joined: 10-October 04 From: Fremont, CA Member No.: 2,918 |
There are two bolts on each side of the car, that are accessed through the wheel well. If you turn your wheel to one side, the bolts should be visible. Sometimes they are heavily covered in dirt and undercoating. (Four total). The rubber top pad is attached to the bumper, while the lower valence is attached to the body and is removed separately after the bumper is out of the way. The fog light grills can stay on the bumper when you take it off.
watsonrx13 |
Sep 14 2008, 06:54 PM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
rhodyguy |
Sep 14 2008, 07:15 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
don't reef on the bolts. if they're rusted up good, you'll be drilling and taping.
Lo-Fi Version | Time is now: 8th June 2024 - 10:14 AM |
