CV joint bolts loose |
JJ914 |
Sep 15 2008, 08:27 PM
Big JJ Group: Members Posts: 90 Joined: 30-December 04 From: Augusta GA Member No.: 3,374 Region Association: None |
Hey my inner cv joint bolts keep getting loose. Thinking of putting a safety wire hole in it aircraft style or maybe some lock tight stuff. I have used new cone washers and they still get loose. What do you think.
type47fan |
Sep 15 2008, 08:30 PM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
See Dr. Evil's EvilWerks CV Safety Wire Bolts in the Member Vendor Forum. They work!
Thanks, |
Rusty |
Sep 15 2008, 08:33 PM
Wanted: Engine case GA003709 Group: Admin Posts: 7,942 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch |
Please, do not use loctite on CV joint bolts.
Usually, if you use new schnor washers and clean out the bolt holes that inevitably get grease in them (I use lots of q-tips), they'll stay tight. You need to retorque them after a certain number of miles. (I use 100 miles as a guide.) P.S. Check the member vendor section. Dr. Evil sells very well done sets of drilled CV joint bolts and wire. (IMG:style_emoticons/default/smile.gif) P.P.S. Augusta isn't too far away. Are you coming to the Rocket City Ramble? (IMG:style_emoticons/default/biggrin.gif) |
Cap'n Krusty |
Clean threads, new serrated washers, new gaskets (although some claim they may be the problem) and correct torque. I use 35 ft/lbs. I rarely have them loosen. One trick you might want to try, if you think shrinking gaskets might be the problem, is to use RTV in place of the gasket. Dr. Evil sells drilled bolts at a very reasonable price. It's difficult to do them without a fixture.
The Cap'n |
JJ914 |
Sep 15 2008, 08:40 PM
OK I promise no loctite. I will clean the bolts and the holes up good install new washers. Makes me feel better to know I am not the only one. I am a airplane mechanic so I will take my bolts to the shop tommorrow and cross drill them for safety wire just to make me feel better about it. Just got my new 2.0 in the hole this week so dont think it will be ready for the trip this year. Time for car work is few and far between. But would love to take her..
Thanks |
r_towle |
Sep 15 2008, 08:45 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
new gaskets.
New schnoerr washers...nothing else works..they are one use only... Clean clean clean. Rich |
JJ914 |
Sep 15 2008, 08:53 PM
new gaskets. New schnoerr washers...nothing else works..they are one use only... Clean clean clean. Rich I got all new washers, gaskets and grease.Think cleaning might have been the problem before they where pretty greasy. I will put them in the parts washer and I just had the axle stubs out and cleaned good when I put new seals in tranny. Thanks everyone is helpful as always |
JJ914 |
Sep 15 2008, 09:05 PM
Does it make a differance which way the washer is installed?
r_towle |
Sep 15 2008, 09:15 PM
I may be wrong but I go teeth towards fastener head.
Rich |
Dr Evil |
Sep 15 2008, 09:40 PM
Nope, the washers go in either way. If it makes ya fell better, you can put it on with the serrations pointing towards the right (IMG:style_emoticons/default/wink.gif)
JJ914 |
Sep 17 2008, 09:37 PM
OK thanks for the info.
Got my bolts drilled up today and they dont look to bad. Shop has a nice drill press with a vise and free drill bits (took quite a few, don't tell the boss). Thanks again for the help. |
Eric_Shea |
Sep 17 2008, 09:40 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Sounds like you didn't have new (or any) Schnorr washers. That's the #1 cause of the bolts working loose.
JJ914 |
Sep 17 2008, 09:49 PM
Sounds like you didn't have new (or any) Schnorr washers. That's the #1 cause of the bolts working loose. I have replaced the washer both times I have had the axles off. Thinking they were not cleaned good enough. But I got new Schnorr's again and cross drilled the bolt so if they come loose again something bad will have happened. |
Mugs914 |
Sep 17 2008, 11:19 PM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
I had one 2.0 that kept shedding CV bolts on the inner driver's side. There was no ammount of cleaning, new bolts, washers, seals, or tourques that would keep those stupid things tight. We tried everything short of Loctite. We even changed the (perfectly good) rolled pins thinking there might be some kind of play or other monkey-motion going on in there. We ended up safety wiring the bolts and that solved the problem (of course), but we never did find out why they kept coming loose.
Must've been the garden gnomes gettin' rowdy with the tools again... |
Lo-Fi Version | Time is now: 8th June 2024 - 01:04 PM |
