914-6 carb/FI ? |
914-6 carb/FI ? |
carcam |
Sep 18 2008, 07:27 PM
Newbie Group: Members Posts: 37 Joined: 22-July 08 From: nc Member No.: 9,334 Region Association: South East States |
Sorry for such a basic question for the real teeners here. I recently got a nice 914-6 and love it- great handling/looks, reliving my younger days. The stock webers are fine but require more tuning than I can do... They are fine at startup but rich, hard to start with when warm (stopping to get gas) , OK when hot, weak at altitiude, etc. Very adjustable but I understand why modern cars went to FI. I've considered a more modern Porsche FI but they can also be just as finicky for the untrained. Now I hear about the PMO carbs and their new throttle body. I can handle adjusting valves, oil changes, points, timing, etc every 5-6k miles or so but the carb thing has me very frustrated- no big deal for most of you but, is there an easier way, even if it costs a little. Since this is the definitive source for all info on my new car, what do you think? Btw, it's stock except 2.2 L when last rebuilt.
Joe Bob |
Sep 18 2008, 07:46 PM
A recent Excellence magaizine discussed the PMO versus the Blitz/Megasquirt EFI.....might want to read up on that.
smontanaro |
Sep 18 2008, 08:25 PM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
I see the September issue has something about adding EFI to early 911s. No mention in the title about PMOs. Is that the article you're referring to?
Skip |
Mark Henry |
Sep 18 2008, 08:34 PM
I did a www.sdsefi.com system for a 2.2 and the guy was quite happy with it. Not going to be cheap.
Most of the time it's linkage issues that screw with the carbs, also sounds like you may have a fuel line to close to a heat exchanger or a pump /regulator problem. |
Joe Bob |
Sep 18 2008, 08:53 PM
brp986s |
Sep 18 2008, 10:12 PM
Member Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
pmo also make throttles for efi. I contacted sds re: this a year ago, but their system used a vacuum sensor which they said is not well suited to individual throttles. A maf sensor is better method in this case and I believe sds was working on it.
Lo-Fi Version | Time is now: 29th May 2024 - 05:22 AM |
