After market coil attachment, anyone have a better way to setup? |
swood |
Feb 5 2004, 10:48 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
The rubber band is just temporary...really. The coil is too small for the stock bracket which is cool. The new bracket doesnt fit the same way.
Attached image(s) |
swood |
Feb 5 2004, 10:49 PM
Sdgf
Attached image(s) |
Joseph Mills |
Feb 5 2004, 11:03 PM
on a Sonoma diet now... Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 |
Is that a Mallory dizzy? If it is, are you using a Mallory CD box also?
swood |
Feb 6 2004, 12:04 AM
Yup
garyh |
Feb 6 2004, 12:07 AM
Member Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 |
QUOTE(swood @ Feb 5 2004, 08:48 PM) The rubber band is just temporary...really. The coil is too small for the stock bracket which is cool. The new bracket doesnt fit the same way. Inner tube. Wrap the coil with a 2" wide strip until it's large enough to be held by the old clamp. I actually use bug weather stripping, which is just a wide flat strip. |
914ghost |
Feb 6 2004, 12:42 AM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
My 3/4 engine tin has two weld-nuts that the stock blue-coil bracket bolts onto. It would be just to the right of the distributor, right behind where it says ZUNDFOLGE 1-4-3-2 ...Seems factory...dont they all have this?
Kargeek |
Feb 6 2004, 01:32 AM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
QUOTE My 3/4 engine tin has two weld-nuts that the stock blue-coil bracket bolts onto. It would be just to the right of the distributor, right behind where it says ZUNDFOLGE 1-4-3-2 ...Seems factory...dont they all have this? I mounted mine there and for my CD ignition box, I made a sheet metal bracket and hung it inder the relay box...it's out of the way. Dave Attached image(s) |
maf914 |
Feb 6 2004, 07:51 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Kargeek,
Nice looking engine compartment. What kind of breather box is that and where did you get it? I have an old VW-style CB Performance type that I really don't care for. Also, what are you using for those right-angle breather fittings? |
Kargeek |
Feb 6 2004, 10:38 AM
My breather box is an aftermarket VW type. It had ribs on the top- I milled them off so the top was flat. You can also grind them off with a belt sander. I mounted the box using a cut down 1.7 heater fan mount. The right angle breather fittings are also VW - don't know where I got them- I may have a few in my stash bins if you need some. Dave Hall
fiid |
Feb 6 2004, 01:23 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
I took a 1" length of 2" copper drainage pipe, cut a quarter inch out of it lenghways (so it looks like a C shape) - slid it over the new coil, and then used the stock clamp. Works like a charm. Don't overtighten the stock clamp because the sheetmetal can tear (Damn PO).
Fiid. |
Lo-Fi Version | Time is now: 10th June 2024 - 02:17 AM |
