'73 2.0 question |
'73 2.0 question |
NOSLIWW |
Sep 23 2008, 02:07 PM
Newbie Group: Members Posts: 3 Joined: 18-September 08 From: Mississippi Member No.: 9,562 Region Association: None |
Just bought my first. Numbers reflect car and engine are 73. It's a 2.0 with dual webers. Engine number is GA0000282. Are the webers a retrofit? Or was it an available option back then?
General consensus? What's better for more power? The dual Webers or with fuel injection? |
Demick |
Sep 23 2008, 02:10 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
All 4 cyl cars came with fuel injection. So the carbs are aftermarket.
Demick |
Oh, and...... (IMG:style_emoticons/default/welcome.png)
TravisNeff |
retrofitted. all 914's were fuel injected. Well, except for the European 1.8's which came carbs.
TheCabinetmaker |
Sep 23 2008, 02:17 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Welcome to the club NOSLIWW
Travis, that was my understanding too till I was corrected by the Cap'n. He said they were all injected. |
TravisNeff |
Sep 23 2008, 02:32 PM
nope, the European 1.8's did come with carbs, check a haynes manual and you'll see em'
Cap'n Krusty |
Sep 23 2008, 02:41 PM
Welcome to the club NOSLIWW Travis, that was my understanding too till I was corrected by the Cap'n. He said they were all injected. I don't remember saying that, but I'm old and my brain is feeble. European 1974 1.8s, for sure, had 2 crappy Solex single throat carbs with the idle circuit for both in the right carb. Throttle plates wore out in about 30K miles, accelerator pump jets fell into the intake ports and they were difficult to tune. I dunno if they had 'em in 1975. All USA version 914/4s were equipped with EFI. The Cap'n |
TheCabinetmaker |
Sep 23 2008, 08:42 PM
Welcome to the club NOSLIWW Travis, that was my understanding too till I was corrected by the Cap'n. He said they were all injected. I don't remember saying that, but I'm old and my brain is feeble. European 1974 1.8s, for sure, had 2 crappy Solex single throat carbs with the idle circuit for both in the right carb. Throttle plates wore out in about 30K miles, accelerator pump jets fell into the intake ports and they were difficult to tune. I dunno if they had 'em in 1975. All USA version 914/4s were equipped with EFI. The Cap'n Hell, i'm old too. Maybe I just dreamed it? (IMG:style_emoticons/default/confused24.gif) |
dbgriffith75 |
Sep 24 2008, 11:07 AM
TheGrif Group: Members Posts: 509 Joined: 25-July 07 From: Iowa, USA Member No.: 7,945 Region Association: Upper MidWest |
QUOTE European 1974 1.8s, for sure, had 2 crappy Solex single throat carbs with the idle circuit for both in the right carb. Throttle plates wore out in about 30K miles, accelerator pump jets fell into the intake ports and they were difficult to tune. I dunno if they had 'em in 1975. All USA version 914/4s were equipped with EFI. The Cap'n Hmm.... maybe I've had some misconceptions about my motor then... because that's what I've got for carbs on mine- two little single barrel Solex carbs. So either the carbs came from a euro motor and this one was still converted.... or it was a euro motor that was installed in my teener... Hmmm.... |
Root_Werks |
Sep 24 2008, 11:27 AM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Nah, someone just tossed on some little carbs was all. If your car runs great and you don't have a ton of money, just leave it be. If you have money and want to do what most of us do, spend it, put bigger carbs on it or convert back to FI. (IMG:style_emoticons/default/wink.gif)
estwing |
Sep 24 2008, 08:04 PM
Newbie Group: Members Posts: 13 Joined: 25-June 04 From: NW Arkansas Member No.: 2,254 |
Just bought my first. Numbers reflect car and engine are 73. It's a 2.0 with dual webers. Engine number is GA0000282. Are the webers a retrofit? Or was it an available option back then? General consensus? What's better for more power? The dual Webers or with fuel injection? Doesn't this engine number indicate it's a 1970 model? |
davep |
Sep 24 2008, 09:40 PM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
davep |
Sep 24 2008, 09:42 PM
Hmm.... maybe I've had some misconceptions about my motor then... because that's what I've got for carbs on mine- two little single barrel Solex carbs. The engine number will indicate the engine type; AN is the carbed 1.8 http://www.914world.com/specs/engnumbs.php |
dw914er |
Sep 24 2008, 09:48 PM
Planning Cities Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California |
motor is 73. No 2.0 4's back in 70 anyways for the 914. All 914-4s were fuel injected cept the euro 1.8's, which were the solex carbs.
Since you have a 2.0 with weber carbs, its been converted. to your question about which is better, it really depends. The stock fi limits the amount of power you can get out of the car (if you make a bigger type 4 like one of raby's kits, youll want carbs) but the fi typically is going to run better stock. Also, the stock fi in working order will suggest the car was better taken care of. Me, I like the FI, and havn't had too many issues with it and welcome to 914world!!! |
estwing |
Sep 25 2008, 07:29 PM
Sorry, I thought the fourth digit indicated the year. I'll have to check my Haynes manual again.
NOSLIWW |
Sep 26 2008, 11:20 PM
Thanks to eveyone for their input!
914werke |
Sep 26 2008, 11:56 PM
"I got blisters on me fingers" Group: Members Posts: 10,119 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
to your question about which is better, it really depends. The stock fi limits the amount of power you can get out of the car (if you make a bigger type 4 like one of raby's kits, youll want carbs) but the fi typically is going to run better stock. Also, the stock fi in working order will suggest the car was better taken care of. Thats debatable. |
dw914er |
Sep 27 2008, 12:24 AM
to your question about which is better, it really depends. The stock fi limits the amount of power you can get out of the car (if you make a bigger type 4 like one of raby's kits, youll want carbs) but the fi typically is going to run better stock. Also, the stock fi in working order will suggest the car was better taken care of. Thats debatable. true, but I have yet to see a 914 with a beefed up type 4 with the stock fi. If its modified then thats another story. |
sww914 |
Sep 27 2008, 03:40 AM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
What's a Raby?
dw914er |
Sep 27 2008, 03:47 AM
What's a Raby? Serious Steve? I guess to be more correct, my "raby" I referred to is one of Jake Raby's "massIVe" type 4 motors he sells. I used it as an example of a beefed up type 4. Even your race car has the carbs on it; I havn't seen a high powered type 4 run the stock fi. |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:15 AM |
