mattp |
Member ![]() ![]() Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 ![]() |
Can someone send me a pic of a throttle pedal stop?
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Here you go.
Attached image(s) ![]() |
mattp |
thanks, can you take it from further out? I need to see where to position it. thanks, matt
BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
You need to set the "Full Throttle Stop" at Full Throttle travel of the pedal/cable.
It does not have a preset position. You need to have a helper open the throttle body on the engine to full throttle (with the stop threaded IN) and then move it out to meet the pedal in it's "Full Throttle Position." Do you have a Haynes manual yet? |
Bartlett 914 |
That is the stop directly behind the pedal. The threaded plate is a part of the pedal board. The white plastic stop may be missing but the plate must be there. Look behind your accelerator pedal an see if it is there. If it is missing ask on the parts section. Should be plenty around and real cheap.
mattp |
i got one, there is no pedal stop at all on my board. i need apic so i can tell where to put this one. matt
Bartlett 914 |
mattp |
there is nothing on the pedal board but I have a used pedal stop i good shape, its the metal base and the plastic bolt. I just need to knowwhere to place the metal base. matt
Bartlett 914 |
there is nothing on the pedal board but I have a used pedal stop i good shape, its the metal base and the plastic bolt. I just need to knowwhere to place the metal base. matt I'll get you a pic tomorrow. Do you have a stock pedal board? If is is a stock one, then the plate should be there or the holes should be. |
Bartlett 914 |
Last one
Lo-Fi Version | Time is now: 16th June 2024 - 10:25 PM |
