Anyone building a deck? Cable railing -, Moved to non 914 section - Trade for 914 stuff??? |
Mikey914 |
Sep 28 2008, 02:04 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Moved to no 914 stuff. Sorry got in wrong area. Honestly, I had never been to that forum.
Will trade for ??? http://www.914world.com/bbs2/index.php?act...=0#entry1085281 Attached image(s) |
736conver |
Sep 28 2008, 04:32 PM
Advanced Member Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
Wrong Forum.
This needs to be posted in Ads: All Other Non-914 Stuff |
Mikey914 |
Sep 28 2008, 04:38 PM
I'm working on a project that has cable railing and the client has decided to utilize another type of railing on some upper decks. I have 18 posts left over that are pre drilled for 12 cables. The overall post height is 37" without any type of top cap. I can provide a top rail or you can use a nice hard wood like Ipe to attach as a top cap into the existing screw races.
These will bolt to the deck surface using 3/8" lag screws on a 5"x5"x 3/8" base plate, I can assist in determining layout if you need a hand. These posts are finished in silver metallic Duranar XL. Not just a powder coat. This is best finish available for salt air exposure. http://corporateportal.ppg.com/NR/rdonlyre...0/DuranarXL.pdf I have 18 posts pre- drilled all the way through, and 4 corner or end posts that are drilled on one side. You can use 1/8" to 3/16" cable the way they are set up. You can obtain cable locally, or I can provide. I'm asking $50 each these would retail for over $95 each. Open to offers, prefer to sell as close to a package as possible. Should be able to ship UPS Ground pretty inexpensively. See some of my projects using this type of product at DIYRailing.com Thanks, Mark Attached image(s) |
Lo-Fi Version | Time is now: 31st May 2024 - 11:17 PM |
