Increased my power range and higher top speed, less than an hours work |
jsayre914 |
Sep 29 2008, 02:13 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I spent a few months replacing every hose on my fuel injected 73 2.0. I replaced every seal, gasket, boot I could find. Sent my injectors out for cleaning. new KN air filter fuel lines etc. My car was running great, I was more than satisfied with acceleration untill....
...fuel pump krapped out. I bought a used one (thanks bdstone914) and swapped it out last night. quick repar. I turned the key and noticed it sounded diff than the old one. The sound was a higher pitch, sounded quite a bit faster than the one I took out. I drove it 60+ miles this morning WOW What a difference It is running faster than ever and more power. Who would of thought, that damn thing was crappin out since before I bought the car in November. Its like I got a new car all over again. (IMG:style_emoticons/default/driving-girl.gif) |
So.Cal.914 |
Sep 29 2008, 02:22 PM
Amazing what a little more fuel will do. Now drive it and enjoy. (IMG:style_emoticons/default/smile.gif)
blitZ |
Sep 29 2008, 02:23 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Cool, that's a nice surprise. Most likely your fuel pressure was low and you were running lean. You may want to invest in a fuel pressure gauge to be sure.
zymurgist |
Sep 29 2008, 02:24 PM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Hmm. type47 had a plan for a cheap fuel pressure gauge (think Home Depot water pump gauge) that I used for Babydoll. I wonder if the old pump wasn't delivering enough pressure to the injectors..?
orange914 |
Sep 29 2008, 04:54 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
Hmm. type47 had a plan for a cheap fuel pressure gauge (think Home Depot water pump gauge) that I used for Babydoll. I wonder if the old pump wasn't delivering enough pressure to the injectors..? i forget if the pressure was tested (i was trying to follow the other threads). if so cant a weak(er) pump sometimes put out acceptable pressure but when a high demand (volume) is needed, (acceleration/load) then pressure falls off, because it can't keep up. i think it should be standard to put a fuel pressure gauge in. i've seen alot of threads dealing with weird drivability problems ending with fuel pressure related fix. i pickedup a nice liquid filled guage on e-bay very inexpensively. glad to hear it's a runner. (IMG:style_emoticons/default/smile.gif) |
Root_Werks |
Sep 29 2008, 05:03 PM
Village Idiot Group: Members Posts: 8,331 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Doesn't D-jet 2.0 run around 28-34 psig? I think anything less would not atomize the fuel very well. I bet your pump was limping along well bellow 25psig.
Dr Evil |
Sep 29 2008, 05:52 PM
29
Lo-Fi Version | Time is now: 3rd June 2024 - 03:11 AM |
