Creamsicle, Gas Tank question |
914Sixer |
Oct 1 2008, 02:49 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
My Creamsicle came in Sunday night. I am stripping it out to go to metal work. Do the cars made in March of 74 have the late gas tank with no carbon canister attached? My early 74(Nov) has the metal cap and two hose openings and a radio hole in the side fender wall. The CS has only one hole for the radio, so I am guessing it needs a late tank, not the early one that was sent.
JeffBowlsby |
Oct 1 2008, 03:10 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The carbon can should be in the engine bay on your CS Mark. My former early 1974 car (Aug 1974, last 5 VIN 01465) had the plastic carbon can at the tank.
Attached image(s) |
jonferns |
Oct 1 2008, 07:35 PM
Advanced Member Group: Members Posts: 2,081 Joined: 29-March 07 From: New Jersey Member No.: 7,631 Region Association: North East States |
My '74 (built 3/74, VIN 15316) has the carbon canister in the engine bay (IMG:style_emoticons/default/bye1.gif)
edit: I've never seen those strut covers in that picture, do you have a closer pic? |
74914LE |
Oct 1 2008, 09:55 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
I believe the point of the original question was well founded. Does anyone know
the point in the 1974 production, when the switch was made to the later style gas tank? |
JeffBowlsby |
Oct 2 2008, 02:04 AM
My '74 (built March '74) has the carbon canister in the engine bay (IMG:style_emoticons/default/bye1.gif) edit: I've never seen those strut covers in that picture, do you have a closer pic? The caps are just the rubber gaskets on the main harnesss that fit upto the back of a headlight bulb. Check it out they fit great and look they were made for teh application...sort-of.... |
watsonrx13 |
Oct 2 2008, 06:38 AM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
My '74, VIN 03058 and 05914 had the canister in the front trunk, but 16472 had it in the engine compartment.... Hope this helps...
-- Rob |
914Sixer |
Oct 2 2008, 04:22 PM
Let me restate my question. Did LE's built in 03/74 has the late tank? I only have one hole in the fender well for the radio. This tells me the correct tank is without the canister and would be the late style. I am enclose in picture of LE and 74 made in 11/73 with 2 tubes and center radio hole.
Attached image(s) |
davep |
Oct 3 2008, 02:37 PM
914 Historian Group: Benefactors Posts: 5,152 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Yes, the charcoal canister goes in the engine compartment in your car.
Lo-Fi Version | Time is now: 9th June 2024 - 11:04 AM |
