Driver side lower than passenger? |
carcam |
Oct 1 2008, 08:49 PM
Newbie Group: Members Posts: 37 Joined: 22-July 08 From: nc Member No.: 9,334 Region Association: South East States |
New to the 914 world. I'm the proud owner of a nice 914-6 with a few minor (I hope) issues. The driver side sits about 3/4 inch lower then the right side. Could it be as easy as a suspension adjustment or weak shock/spring on the left or something more serious like rust, frame sag, etc. The windows and gaps are good- nothing obvious. I can't get the ebrake light to turn off but I'll check the master cylinder for that (read that here). This car is a blast- I can't imagine keeping one up without this forum and the the wealth of information from all the experts here. The more I read here the more I learn. Thanks. (still don't know what the hell hole is and I don't want one and if I already have one I hope it's not rusty).
jdogg |
Oct 1 2008, 08:55 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
Where in NC are you??? There are quite a few of us on here...
r_towle |
Oct 1 2008, 09:24 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Could be a few things.
Check the rear springs to make sure they are not broken on that side. Check the torsionbar up front to make sure its not broken. Both of these spring steel items do break after 37 years... Both are not to expensive to fix. It could also be a worn or sagging spring (37 years of one person in the car 100 percent of the time) It could also just be out of adjustment.. the front is adjusted by an 11mm bolt on the rear of the torsion bar. the rear could be on adjustable spring perches already... suggest you bring it to a shop and show them...they can figure it out, its simple and it will be a good test to see if you can trust them and you can work with them long term. Rich |
orange914 |
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
unbolt the sway bar links before you do anyadjustments or replacements
hell hole is under/around the battery, where corrosion is usually worst (IMG:style_emoticons/default/welcome.png) mike |
carcam |
Oct 2 2008, 12:48 PM
Thanks guys! Sure appreciate it. I live in Greensboro- didn't think there would ever be another 914 around since I haven't see one in years.
dlee6204 |
Oct 2 2008, 01:28 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
There's more than you think. There's quite a few in the Winston Salem area I know about.
Richard Casto |
Oct 2 2008, 03:53 PM
Blue Sky Motorsports, LLC Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
Welcome to the forum!
And yes, there are a handful of us in the Triad/Triangle area. |
carcam |
Oct 3 2008, 05:13 PM
70Sixter |
Oct 4 2008, 01:37 PM
Member Group: Members Posts: 422 Joined: 3-August 04 From: Surf City, NC Member No.: 2,444 Region Association: South East States |
It is also possible the car has been corner balanced for proper weight distribution. Altho I'd think that would leave the driver side higher.
AgPete139 |
Oct 5 2008, 01:23 AM
AgPete139 Group: Members Posts: 90 Joined: 12-February 08 From: Houston, TX Member No.: 8,701 Region Association: South East States |
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/welcome.png)
And these guys have a lot of experience with these things. Good luck... |
Lo-Fi Version | Time is now: 8th June 2024 - 12:24 AM |
