stiff acell pedal |
stiff acell pedal |
loflyer |
Feb 7 2004, 02:36 PM
Newbie Group: Members Posts: 1 Joined: 6-February 04 From: granitefalls wash Member No.: 1,638 |
HAVE 914 71 2.0 WITH CARBS JUST PURCHASED OUT OF ARIZONA CLEAN CAR . THIS CAR HAS A VERY STIFF ACELL PEDAL. HAVE READJUSTED ARM ON CROSS BAR HELPED A LITTLE. BUT STLL TO STIFF.NEED SOME HELP GUYS? (IMG:style_emoticons/default/smash.gif)
r_towle |
Feb 7 2004, 04:05 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Dissconnect it from the Carb linkage and make sure the cable and joints up front are free and move nicely...
If that is all right, you might have a linkage geometry problem. Rich |
ChrisFoley |
Feb 7 2004, 04:13 PM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
All throttle return springs are located in the engine comp. Do like Rich says, disconnect the cable from the linkage and see if the pedal is still stiff. If it is, then the problem is likely either the cable or the pedal bushings.
Another problem that sometimes occurs when replacing a cable is that the throttle cable gets wrapped around the clutch cable in the front of the tunnel. This can cause a stiff pedal as well as the engine revving when the clutch is depressed. |
Jeffs9146 |
Feb 7 2004, 06:23 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE Another problem that sometimes occurs when replacing a cable is that the throttle cable gets wrapped around the clutch cable in the front of the tunnel. This can cause a stiff pedal as well as the engine revving when the clutch is depressed. (IMG:style_emoticons/default/agree.gif) That happend to me!! It can also get wrapped around the shifter! Jeff |
ChrisFoley |
Feb 7 2004, 06:35 PM
QUOTE(Jeffs9146 @ Feb 7 2004, 07:23 PM) It can also get wrapped around the shifter! How can that happen? The tube the cable is inside terminates ahead of the shift linkage. |
Jeffs9146 |
Feb 7 2004, 06:39 PM
QUOTE How can that happen? The tube the cable is inside terminates ahead of the shift linkage My tube was broken and had a hole rusted in it!! It was a 74 that I owned when I was in my 20's! It caught on fire! jeff |
Demick |
Feb 7 2004, 08:00 PM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
[quote=Racer Chris,Feb 7 2004, 04:35 PM] [/QUOTE]
How can that happen? The tube the cable is inside terminates ahead of the shift linkage. [/quote] The tube terminates ahead of the shifter - but it doesn't get wrapped around the shifter, the throttle cable gets wrapped around the clutch cable. When you thread through a new accel cable, it naturally wants to wrap itself around the clutch cable - so you need to get a mirror and look in the end of the tunnel to make sure the cables are free of one another before hooking them up. Demick |
Brad Roberts |
Feb 7 2004, 10:58 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
If your OE cable housing is broken at the firewall.. the pedal becomes REAL stiff. The OE housings have a white plastic sheeth in them that holds the cable. They tend to break when you try and make tight turns with it. I use Terrycable. No inside sheeth and better wound cable (aircraft quality).
B |
Aaron Cox |
Feb 7 2004, 11:03 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
brad... i had a problem with a bad terry cable. they made a batch that the threads on one end werent cut right/straight/didnt fit the nuts they supplied. went all over town trying to find the right nuts. nothing fit (metric standard pitches of threads!). i called them and they said a couple of em werent cut right and they sent me a good one.
Aaron |
Brad Roberts |
Feb 7 2004, 11:07 PM
Shit happens (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/laugh.gif) You cant win them all. They are assembled in America..
I havent ran across any bad ones. B |
Lo-Fi Version | Time is now: 1st June 2024 - 08:29 AM |
