Electric Windshield Washer Motor, Where is the stock placement |
jesiv |
Oct 8 2008, 06:39 PM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
Ok so I am upgrading my windshield washer system from air to the 914-6/911 electric motor. I have seen Sir Andy’s thread
http://www.914world.com/specs/tech_el_washer.php However, it looks like he drilled holes in the metal. Is there a stock place to mount it or atleast a place to mount it without drilling holes? Or just drill the holes and mount the sucker. Does anyone have pics of how they did it? Thanks for the help! Regards, James |
SirAndy |
Oct 8 2008, 06:58 PM
Resident German Group: Admin Posts: 41,688 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
However, it looks like he drilled holes in the metal. Is there a stock place to mount it or atleast a place to mount it without drilling holes? Or just drill the holes and mount the sucker. I installed mine in the 914/6 location. The /6 has holes there from the factory and uses rubber plugs to mount the pump. (IMG:style_emoticons/default/bye1.gif) Andy |
jesiv |
Oct 8 2008, 07:30 PM
So Andy, were the holes threaded (if threaded what size) or did you just use sheet metal screws? I can't tell from the pic? Also, how many screws?
SirAndy |
Oct 8 2008, 07:55 PM
So Andy, were the holes threaded (if threaded what size) or did you just use sheet metal screws? I can't tell from the pic? Also, how many screws? I cheaped out and just drilled holes and used bolts. I did, however, sandwich a layer of rubber inbetween to insulate against some of the noise. I believe the stock /6 uses 3 rubber plugs. Here's a pic from my original /6 project that shows the holes ... (IMG:style_emoticons/default/shades.gif) Andy Attached image(s) |
davep |
Oct 8 2008, 08:50 PM
914 Historian Group: Benefactors Posts: 5,159 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Did you see the switch I made up to replace the valve?
http://www.914world.com/bbs2/index.php?s=&...st&p=870714 |
Lo-Fi Version | Time is now: 17th June 2024 - 05:04 AM |
