| mikeyboy_85 |
Oct 12 2008, 07:11 AM
Member ![]() ![]() Group: Members Posts: 82 Joined: 24-May 07 From: australia Member No.: 7,758 |
Hey guys, the brake lines in my 914 are buldging so i need to get new lines, my car is fitted with 5 stud rotors and brakes from a 911(so im told) so im not sure what lines i need to get, and i also need to replace the linings and not sure which ones to get. The brakes look to be the same as an early 911 or 912 but not sure if i should get 914 lines or 914-6 lines due to 911 brakes??
cheers any help would be great! Michael |
| jimkelly |
Oct 12 2008, 07:28 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
| Dave_Darling |
Oct 12 2008, 02:14 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I believe the 914 flex lines will not have the correct fitting on the caliper end. Likely the Six lines will, but I am not completely sure.
You can figure out which 911 brakes you have with a couple of tests. First, check the bolts that hold the caliper onto the strut. If they are 3" apart (center to center), you have "M" calipers, so the original 914-6 parts should be perfect. If you have 3.5" bolt spacing, then see if a magnet sticks to the caliper. If it does not, you have aluminum "S" calipers. If so, you have steel "A" calipers. I think the Six lines will work for those, but I could be wrong. Note that I haven't done this swap yet, so I am not talking from first-hand experience. --DD |
| mikeyboy_85 |
Oct 12 2008, 09:38 PM
here are some pics of the front and rear brakes and lines as fitted to my car, im pretty sure the rear are stock but redrilled for 5 stud, but the fronts im not to sure about, but im sure that u guys will be able to tell me from the pictures
cheers Attached image(s)
| mikeyboy_85 |
Oct 12 2008, 09:40 PM
sorry bout bad pics, taken on phone
| GeorgeRud |
Oct 12 2008, 09:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Go with the same lines as you have. They should be available at any of the usual suspects (Pelican Parts, Performance Products, etc.), and proably still available through your friendly Porsche dealer (though probably at a much higher price). It looks like you have the stock 914 brakes, so there should be no surprises.
| mikeyboy_85 |
Oct 12 2008, 10:22 PM
thanks mate! will get them from pelican parts
| mikeyboy_85 |
can someome tell me what linings i would get for the front?
| Dave_Darling |
Oct 13 2008, 12:51 AM
Those front hubs look like 911 parts to me! Measure the mounting bolts and see if they're magnetic, and you'll have a much better idea of what pads to get.
Again, I'm not at all sure that the 914 flex lines will fit the 911 calipers... --DD |
Lo-Fi Version | Time is now: 7th March 2026 - 02:11 AM |
