| moggy |
Oct 12 2008, 05:09 PM
Member ![]() ![]() Group: Members Posts: 192 Joined: 15-December 04 From: Wales Member No.: 3,285 |
Will be fitting some GT wings from AA soon. The question is what 5 stud wheels to fit.
I'm restricted to 6inch width due to race rules. I want to stick with Fuchs. So what offset Fuchs do I need? I'm completely green to this so I don't know if there's a certain serial number to look for in a Fuch wheel that ='s the offset. All help and advice greatfully received (IMG:style_emoticons/default/smile.gif) |
| rfuerst911sc |
Oct 12 2008, 06:59 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
When you say you'll be adding GT wings from AA do you mean fender flares? If that's what you mean I think you're going to have a hard time getting 6 inch wide wheels to look right as they will be too narrow. The Fuchs 6 inch wheels in 15 or 16 inch diameter have an offset of 23. Most guys with flares are running at least 7 inch wide wheels up front and at least 8 in the rear if not wider on both ends to " fill out " the flares. I guess you could add spacers to push out the wheels but it's still going to look funny with skinny tires.
| ConeDodger |
Oct 12 2008, 07:01 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,497 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California
Moggy,
I suspect most around here don't understand what you mean by wings... That may explain the silence. If your race rules limit your width to 6" and you want to stick with Fuchs you have a choice between 15" and 16". I would go with the 16" as they offer more tire (or I guess in this case tyre) choices. I fit 16X6 SC or Carrera wheels on my narrow body without pulling fenders or rolling the lip. These are found on the '79 - '89 911. I have 205 50X16 tires on there now. No rubbing occurs without modification. With your flared "wings" you can go much much wider. I have heard of 11" wheels and seen 9" in the rear. I have seen 8" front but it seems to me that 7" would help with steering effort. You will need spacers to move the 6' wheels outward for the flared "wing". I think there is a part# chart for Fuch wheels on Pelican Parts forum... Good luck and no... There is now chance the US will be rejoining the UK (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 11th July 2026 - 12:17 PM |
