Fan to J tube paper heater hose, Good replacement from NAPA |
IronHillRestorations |
Oct 14 2008, 02:33 PM
I. I. R. C. Group: Members Posts: 6,731 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I did a little research at my local NAPA store, and found a 60 mm x 1000mm, black, paper/foil/paper, hose that's very close to OEM. NAPA part number is 813-1374 "Carburator Preheater Hose". $8 and change. They don't have one long enough to go from the fan to the passenger side, but it's not too hard to connect two together. $25 for three is probably cheaper than most vendors sell one for.
Bartlett 914 |
Oct 14 2008, 03:53 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I did a little research at my local NAPA store, and found a 60 mm x 1000mm, black, paper/foil/paper, hose that's very close to OEM. NAPA part number is 813-1374 "Carburator Preheater Hose". $8 and change. They don't have one long enough to go from the fan to the passenger side, but it's not too hard to connect two together. $25 for three is probably cheaper than most vendors sell one for. Thanks for the info. It is nice to save a little and to also find things locally. (IMG:style_emoticons/default/aktion035.gif) |
Cap'n Krusty |
Oct 14 2008, 04:31 PM
I did a little research at my local NAPA store, and found a 60 mm x 1000mm, black, paper/foil/paper, hose that's very close to OEM. NAPA part number is 813-1374 "Carburator Preheater Hose". $8 and change. They don't have one long enough to go from the fan to the passenger side, but it's not too hard to connect two together. $25 for three is probably cheaper than most vendors sell one for. "Very close to OEM"? How can paper/foil be very close to plastic in look? The Cap'n |
gary gartner |
Oct 14 2008, 05:06 PM
i know more than a newbie---way less than a guru Group: Members Posts: 239 Joined: 16-December 04 From: Valencia, Ca Member No.: 3,294 Region Association: Southern California |
I have found perfect replacements at the local Bug Shop. Passenger side to fan need to be joined, but Inside diameter is perfect. Gary (IMG:style_emoticons/default/beerchug.gif) |
Oct 14 2008, 09:11 PM
Sorry Cap'n, I meant to say it looks like the 914-6/911 black paper hose.
Lo-Fi Version | Time is now: 8th June 2024 - 10:23 PM |
