Shift bushing r&r, experience / Comments? |
914ghost |
Feb 8 2004, 03:20 PM
BOB Group: Members Posts: 406 Joined: 25-November 03 From: Wenatchee Washington Member No.: 1,387 |
I've got a tailshifter and have my shift linkage completely removed front to back- I was wondering what advice or experience anyone has on top of replacing ALL bushings that helps get these things shifting as well as can be expected.
It was actually not too bad before, when in 1st/reverse there was little or no play, but 2nd-5th had some slop. The plastic 2 'balls" at the pivots just snap off? Also, My rear shift rod had "some" wear at the rear bushing at the nose-cone, anyone ever epoxy/JB weld this area to get it flat again? Seems like it should hold up through a plastic bushing. Also, the "ball" at the tail end of the shift rod has 2 small flat-ish spots where its worn at the shift selectors, is this worn, or should they be like this for free shifting? Is a short (weltmeister) shift kit worth it in a tailshifter? Anything to tell me? TIA (IMG:style_emoticons/default/smile.gif) Bob O |
914ghost |
Feb 8 2004, 07:42 PM
Nothing?
Noone has ever done this.. .? Thats hard to believe... . .... Is the subject not interesting or NOT off-topic enough? (IMG:style_emoticons/default/sad.gif) |
seanery |
Feb 8 2004, 07:52 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
Bob,
I think you and I are the only folks still running a tailshifter. Brad & Mark put mine back together when they did the motor, so I don't have any good advice here. |
914ghost |
Feb 8 2004, 07:58 PM
Just for that I'm gonna start buying side shifter and RETROFIT tail shift tranyy's into ALL of em!! (IMG:style_emoticons/default/wacko.gif)
drew365 |
Feb 8 2004, 08:17 PM
These are the good old days! Group: Members Posts: 2,004 Joined: 29-December 02 From: Sunny So. Cal. Member No.: 37 |
I don't have a tail shifter, so the only thing I can comment on is the worn shift rod at the rear bushing. If there is still play after installing a new bushing you can take it up by forcing a tiewrap in the opening around the bushing. I did this, I was only able to get a small size tiewrap in but it really tightened up the movement. I greased the area with some poly lubricant.
Gint |
Feb 8 2004, 08:30 PM
Mike Ginter Group: Admin Posts: 16,082 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Easy there bub...
I haven't put mine back together yet, so I can't be of much help at the moment. But I'll happily bump the thread for ya. |
rhodyguy |
Feb 8 2004, 08:59 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
bob, it's all pretty straight forward. when i did a tailshifter the improvement was pretty substancial. the shortshift kit improved things also. i didn't like the stiff springs that can be bought for the shifter though. there are 2 bushing that cradle the shifter ball and spring, get those too. clean the stock springs well. when you go to put the one in the firewall micro wave it in some water to soften it up and it will go in much easier. you may have to weld up the rear rod and reshape. i didn't go that far. watch out for the springs when you take the shifter apart. they can fly across the garage.
kevin |
Lo-Fi Version | Time is now: 6th June 2024 - 11:51 PM |
