Pedal Cluster Brake Switch |
7TPorsh |
Oct 23 2008, 12:09 PM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
Well i traced my faulty brake lights to a bad cluster switch; i think. I bridge the two wires and I get light, but on switch no light.
Going to take it out and try to clean it. My question: Will the switch work if it is not mounted? ..hold in my hand and pull on lever...should it work in my hand? or it has to be mounted/grounded? thx |
ArtechnikA |
Oct 23 2008, 12:34 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
southernmost914 |
Oct 23 2008, 12:54 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
My question: Will the switch work if it is not mounted? yes. two wires - one hot, one ground. it does not ground through the case. Two wires -One positive ,one load, switch is spring loaded and normaly closed ( unmounted lit) Steve |
Jeffs9146 |
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE yes. two wires - one hot, one ground. it does not ground through the case. I don't think that is an accurate discription. I think is goes more like, the wires on the switch are a hot wire that completes the circuit and the ground is at the tail light! (IMG:style_emoticons/default/shades.gif) Edit: (IMG:style_emoticons/default/sad.gif) Steve beat me too it! |
7TPorsh |
Oct 23 2008, 03:56 PM
Weel, took it out, saw how it worked. Turns out even with brake pressure, the switch wasn't clicking.
i mounted it and bent the liottle lever until the slightest bit of pressure triggers the switch. Voila! Now i just need to get a pedal board cause I broke it doing all this...least I don;t need a switch too. |
ArtechnikA |
Oct 23 2008, 04:10 PM
Now i just need to get a pedal board cause I broke it doing all this... Pity - that's one of the few inexpensive parts on the car... The aluminum pedal boards are a nice upgrade. At least one supporting vendor here makes one that has got very good reviews. 'Search' is your friend - have a look in the 'member vendor' section. |
Cap'n Krusty |
Oct 23 2008, 04:45 PM
You DO have the arm of the switch on the side of the pedal washer nearest you, right? It doesn't go under the washer .................
The Cap'n |
7TPorsh |
Oct 23 2008, 05:08 PM
You DO have the arm of the switch on the side of the pedal washer nearest you, right? It doesn't go under the washer ................. The Cap'n Yes , I have seen your many posts regarding this while hunting in search. I seemed like I really had to put the pressure on the pedal to make the lights go on. Now I pulled on the lever a little so the travel on it is lessened. It works...probably won't know for sure until I get everything together and on the road. (IMG:style_emoticons/default/biggrin.gif) |
7TPorsh |
Oct 23 2008, 05:11 PM
Now i just need to get a pedal board cause I broke it doing all this... Pity - that's one of the few inexpensive parts on the car... The aluminum pedal boards are a nice upgrade. At least one supporting vendor here makes one that has got very good reviews. 'Search' is your friend - have a look in the 'member vendor' section. Saw these but I think he is out of stock? Double the price of the repro at AA; I just can decide if I want to expose it all or let the carpet cover it up. |
ArtechnikA |
Oct 23 2008, 05:31 PM
Saw these but I think he is out of stock? Double the price of the repro at AA; I just can decide if I want to expose it all or let the carpet cover it up. here is another source: RennLine. I have these in my 911 (much as I like Engman's products and his 914 speciality, the 911 needs stuff too...). I always thought the wooden bits was - quaint. Plywood was probably cheaper in the late '60's when the cost-accounting on these cars was done. But do what you like - it's your car. |
Eric_Shea |
Oct 23 2008, 06:12 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I have some switches if you need one.
Lo-Fi Version | Time is now: 10th June 2024 - 07:19 AM |
