LetoAtreides |
Member ![]() ![]() Group: Members Posts: 86 Joined: 15-May 07 From: Half Moon Bay, California Member No.: 7,739 Region Association: None ![]() |
For some reason My clutch no longer fully disengages. The throw is adjusted properly (the adjustment is the same as I've always had it), but pushing the pedal only yields about 3/4 of an inch of movement from the clutch cable. Also, pushing the pedal is really easy now. What's wrong? Is the cable stretched?
bam914 |
Member ![]() ![]() Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None ![]() |
Your clutch tube may have broken through the firewall or it broke loose from the welds inside the center tunnel. You will need to look in the tunnel on the left side and look for the tube moving.
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
Lotsa stuff on this site to help,
http://www.914world.com/bbs2/index.php?act...ite=clutch+tube I hope its an easy fix (IMG:style_emoticons/default/biggrin.gif) |
LetoAtreides |
How much would it be moving if it was broken, because it moves a little, but not much, although it seems to be bent. Is this normal?
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
check the clutch cable at the firewall, if it was broken for a while this area may have given in.
cwpeden |
Great White North, huh? ![]() ![]() ![]() Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada ![]() |
Just happened to a buddy of mine. The clip that holds the end of the cable housing to the trans(just before the roller) came off. Same symptoms.
Good luck. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,991 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Did you recently replace the pedal bushings? If so, the roll pin in the pedal cluster is failing. The one in the bronze bushing kit isn't so great.
Check to see if the shaft the pedal rides on is turning as much as the pedal is moving. If not, it's the roll pin. --DD |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Take the rear access plate off of the inside tunnel.
Sit in the drivers seat and reach in with your right hand and feel the tube on the sidewall of the tunnel closest to the driver. As you have your fingers on the tube, actuate the clutch.. If the tube moves at all, you need to find out where. The tube is held in place (and it must be) at the rear of the firewall and just in front of the shifter. The front one typically goes and is not that hard to fix... If you cannot weld, and cannot find a welder to help you I have seen various methods to clamp the front tube to the sidewall of the tunnel. I think Slits did this, he may have a few pics of how that works... I would prefer to weld it back up. Rich |
Lo-Fi Version | Time is now: 10th June 2024 - 07:22 AM |
